Resolution problem
y6053287
my FreeNAS device is connected to a display but the resolution is incorrect and part of the left side of the text is cut off.
how can I fix it?
Redcoat
Redcoat
No, there is no answer in that closed bug report. You can see that they were waiting from more information from the original reporter @Constantin , but that did not happen. I am sure I saw the problem but I could not reproduce so could not contribute. I suggest that you file a new bug report with screenshots, etc.
No, there is no setting for the console window in the GUI.
Constantin
Vampire Pig
Ooops, I must somehow have missed that message. I didn't think to check either. I will try to reply / reopen the ticket.
FWIW, I was able to get my monitor to resync several times on on the 8th try, the console is fully back.
how can I fix it?
This is generally a problem with monitor scalers, not the video output, and having them do an auto setup tends to fix it.
I see the same thing on my IPMI KVM--seems unlikely that has anything to do with the monitor scaler.
Edit: Well, I did. But when I launched the viewer just now, I'm not seeing it. Strange.
SweetAndLow
Sweet'NASty
I see this happen on some of my monitors. I just fix the monitor and slide the screen over.
MDA/CGA/EGA/VGA text modes all output oddball resolutions by today's standards. They're wider than 4:3 if used with square pixels, which tends to trip up some monitors.
Now that is really weird. I seem to recall some weirdness a few years back with a graphical console mode?
Redcoat
"Now you see it, now you don't" - that's what happened to me on the Asrock IPMI KVM view, too, when I joined in the initial bug report. I felt forced to conclude that I had dreamt it ...
