SOLVED resize iscsi file extent?
Elias Pereira
I have a freenas 9 installed on a xenserver. I did the
procedure to increase the disk in xenserver and also in freenas.
I checked and the extent file I have configured for
a debian client is still at the old disk size.
Is there any way to resize this file?
HoneyBadger
actually does care
Administrator
Just so I'm clear:
FreeNAS is installed as a guest on XenServer, using virtual disks as backing storage. You've resized the virtual disk Xen is presenting to FN and FN sees the new size.
You're running an iSCSI file extent for a Debian guest - is the guest under XenServer or bhyve in FreeNAS?
Have you resized the file extent itself from within FreeNAS, and triggered a SCSI rescan/refresh from inside Debian?
Elias Pereira
Under xenserver
I tried to resize the extent file with a
truncate -s +16G /mnt/strdc3/strdc3.file
but apparently it didn't work.
Is there another way to do this?
Elias Pereira
Now it worked with reisize2fs directly on the guest OS (debian). I was forcing the unmounting of /dev/sda, but I was not stopping the samba4 services. So it wasn't completely unmounted.
I did that now and was able to resize.
Thanks for the great help!!!
