Pretty simple: I need to reset my Truenas (IXSystems) Mini. I just want to reset iit back to factory defaults. I have no csaved config on it. JUst want to start over. I do now have access to the VGA dongle for my monitor. Thank you.
Can you SSH into the box? If so, run /etc/netcli to get the console menu; one of the options there is to reset to defaults. Or you can use the shell button in the web UI and run the same command.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
