BilliusWillius
- Oct 22, 2014
Since I'm soliciting opinions, I'll start with why I want this built. I have a small home network which serves one user who has >13Tb and some other users (only one other who breaches a Tb in space requirements). Most of the data I intend to put on the server is inconsequential, and already exists on optical disk as a backup. I'd prefer to keep all the data on live disks so it can be accessed as desired and to aide ease of backup as well.
My idea:
Case+motherboard = SuperMicro: SSG-6047R-E1R36N (http://www.supermicro.com/products/system/4U/6047/SSG-6047R-E1R36N.cfm)
CPU = Intel: E5-2603 v2 (http://ark.intel.com/products/64592...-2603-(10M-Cache-1_80-GHz-6_40-GTs-Intel-QPI))
Memory = Hynx: 4x8Gb DDR3 1600 Registered ECC (http://www.newegg.com/Product/Product.aspx?Item=N82E16820161697)
Heatsink = Supermicro: SNK-P0048AP4 (http://www.supermicro.com/support/resources/thermal/)
The HDDs are all consumer grade SATA3 (a mix of WD and Seagate, namely whatever was on sale), right now there will be 11 of them in a RAIDZ3 (all but two have been in use for about a month and so far no bad blocks or noticeable decay). The current CPU linked above is only a stopgap, as the system needs to be operational fairly soon (about a month or so before it must be running in a state which can start holding the network's data) and cost is a large issue (shaving $200 off startup cost is a big deal for the current build). Once more sufficient funds are available the CPU will be upgraded to something which supports turbo boost and hyperthreading. I'll be implementing encryption due to confidential documents which will need to be stored, and I'm aware that the CPU is underpowered for that kind of task, but as long as it can get the job done and won't have the computational equivalent of a heart attack, it can wait. Mostly the constraints on the system are price, as I had a rather difficult time finding validated ECC memory for the SuperMicro board and after reading some of the stickies about ECC I didn't want to roll the dice on my memory giving problems.
My reasoning for the case and board were for expansion later, since there might be a need for more storage later, and there will definitely be a need for better and beefier CPUs (to handle encryption mostly, possibly some transcoding for other users once their home movie collection is on active drives rather than locked away on DVD/CD/VHS).
I included the heatsink on the off chance someone's had issues with it before, I looked but I didn't see anyone report issues, and I'm a touch paranoid about overheating CPUs since I cooked one in a system some 10 years ago (I was younger and stupider then, and I don't use my computers as a footstool anymore regardless of how comfortable an ottoman they are).
My idea:
