PacothePig
- Sep 8, 2022
Hello all o/ first time poster, medium lurker. as title states im planning on a new build from my current one and want to get the parts list correct so i dont needlessly spend like i did the first time.
I am not new to PC building, i have built plenty of desktops in the past, but reading through posts and other's questions on builds has left me confused. i have read the Hardware 2021 R2a pdf, and i must say while some of the info in it did clear up things i didnt understand before (like the sata controller section, types of disks), for the main hardware (mobo and cpu and such), i must say im more confused than before.
my current build is using the second mobo i ever bought in my life (11 years and still kicking!) that id like to retire again in favor a proper build instead of the frakenstein i put together:
Mobo: Asus Sabertooth 990FX R2.0
CPU: AMD FX(tm)-8350 8 core
PSU1: Corsair 650
PSU2: Corsair 650x (yes two PSU's, my worry being too much draw on one PSU and instead splitting the load. probably overboard but just in case...)
HDD: (there is a reason why they are a mix, see footnote)
-4x WD Purple 4TB 5400
-5x Seagate 4TB 5400
HDD Controller: https://www.amazon.com/gp/product/B07NFRXQHC/ (dont judge me, i didnt know what i was doing and was desperate to make it work)
since i dont want to run through a repeat of past mistakes, i would like advice based on my target goal and starting point
target goal: 10 disks (expandable, likely as two separate pools once i decide to get 11+ disks in the system), low-ish usage (storage of long term data, occasional stream of video) but strong enough to last a long time without needing a hardware upgrade. medium budget (though wouldnt surprise me if my goal hits the high side).
my starting point is this motherboard:
https://www.asrockrack.com/general/productdetail.asp?Model=E3C246D4U#Specifications / https://www.amazon.com/dp/B08DTTMPKC/
with this CPU:
and this memory:
from there the harddrives i have now i will continue to use until i can replace them later with more recommended ones that i see in other posts (ex. the 5400 nas types).
will use a small (128 likely) nvme for boot disk
for the PSU(s), based on whether my starting point is correct i will check the estimated peak wattage to see if buying a single PSU to handle it all is better, or to continue using both for whenever i want to expand or start a second pool.
where i need the advice on:
Greatly appreciate any and all advice given
footnote - aka why the mix of HDDs:
so i started out as one of those people that bought a WD 'passport' for data storage. then moved to a 'my book' and kept upgrading its size as time went on. at one point i had two and worked alright, until the day one nearly died without me being able to transfer the data out in time. ever since then i was curious about the concept of RAID as a mirror or even better RAID5. not wanting to spend 700+$ on those fancy RAID devices (synology), i opted for some of those USB3.0 raid holders with the switches in the back that set the configuration, as trying to do a RAID5 via the bios wasnt always available (or caused more problems). that went for a while until windows started acting weird with the device, sometimes outright refusing to communicate or causing the device to stay in a non-responsive state. so when looking up another better solution, i came across FreeNAS/TrueNAS as a solution, and found its concept to be exactly what i wanted. hot-swappable, RAID5 and even the ZFS data structures. but, at this point i had bought TWO of those usb raid devices, each having a different type of drive, WD for one, Seagate for the other. i didnt have budget at the time for getting all of the same drive, so i just went with what i had on hand. seeing it come to life and working, i continued with it
PSU1: Corsair 650
with this CPU:
and this memory:
- the first three parts, are these supported / correct / good enough choices? if not, what am i misunderstanding or could theoretically be better?
- the board only has 8 sata slots. for me to get back to my 9 disk configuration, i will need a proper controller. i had previously (and erroneously) bought this card https://www.amazon.com/gp/product/B01M2AC40Y/ which the older mobo didnt like. would this work or am i incorrect on the kind of hba that works? and if i am incorrect, what would work with this board?
- regarding powering HDD's, the Hardware guide states that the molex connector is better than the sata ribbon that typically has 4 plugs in a row. should i buy extra molex power cables and molex to sata adapters or is that not what is being suggested? cause PSU's typically come with one maybe two of those molex types
- anyone with experience on these kinds of boards, does the hdmi port on these boards work without any additional stuff required for the cpu or if i get the cpu listed above, am i still going to need a graphics card for initial install?
