melp
- Apr 4, 2014
I'm looking to update an existing SMART status report script with information from SSDs, but information online about SSDs' smartctl output is limited. If you have an SSD in your machine with SMART support, I would really appreciate it if you would post the output of the following command run on that SSD:
You can get the <SSD ID> value by running
The output should look like this (obviously, you can block out your drive's serial number):
smartctl -A -i /dev/<SSD ID>
camcontrol devlist
.The output should look like this (obviously, you can block out your drive's serial number):
=== START OF INFORMATION SECTION === Device Model: INTEL SSDSC2KW120H6 Serial Number: LU WWN Device Id: 5 5cd2e4 14cbe78ff Firmware Version: LSBG200 User Capacity: 120,034,123,776 bytes [120 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-3 (minor revision not indicated) SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Aug 6 20:58:23 2017 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Reallocated_Sector_Ct 0x0032 100 100 000 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 3 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 17 170 Unknown_Attribute 0x0033 100 100 010 Pre-fail Always - 0 171 Unknown_Attribute 0x0032 100 100 010 Old_age Always - 0 172 Unknown_Attribute 0x0032 100 100 010 Old_age Always - 0 174 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 5 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0033 100 100 090 Pre-fail Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0032 028 042 000 Old_age Always - 28 (Min/Max 15/42) 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 5 199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0 225 Unknown_SSD_Attribute 0x0032 100 100 000 Old_age Always - 1494 226 Unknown_SSD_Attribute 0x0032 100 100 000 Old_age Always - 0 227 Unknown_SSD_Attribute 0x0032 100 100 000 Old_age Always - 0 228 Power-off_Retract_Count 0x0032 100 100 000 Old_age Always - 0 232 Available_Reservd_Space 0x0033 100 100 010 Pre-fail Always - 0 233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 0 241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 1494 242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 1677 249 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 47 252 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
