Reporting tab not working
Max Hughes
Hi all,
I've had my first build up and running for a few weeks now. I'm wanting to monitor the system e.g CPU utilisation during different tasks, disk and memory use, CPU and Drive temps.
Unfortunately the reporting tab isn't working. I've tried restarting the system but no difference.
If I look at the graphs they are just blank.
Any idea whats happening or if there is a better way to monitor the system e.g plugin ?
I've attached some images to show what I mean. Current uptime is 2 days but still no data.
Nucshuco
system > system dataset is there a check mark in syslog?
SweetAndLow
Sweet'NASty
What errors are in the logs? You can upload the debug file if you want
SweetAndLow
Sweet'NASty
either by selecting the option to put the logs in the footer of the web ui. This setting is under the setting section of the gui. Or you can use the command line to open the logs, i suggest the tool 'less' to open and view logs. You can also just download the debug file from the gui and upload it here.
