SOLVED Reporting graphs not reporting after hardware upgrade
diedrichg
After upgrading my hardware (mobo, cpu & RAM in my signature) my Reporting graphs no longer report for Disk, Memory, Partition and System. The CPU and Network graphs are working. I'm assuming there is a conflict in a config file. Is there a config file I can delete / reboot and let it recreate the file? I'm on 9.2.1.6-RC2 and they were working just before I swapped out the parts this evening.
diedrichg
nevermind - Right before I went to bed last night after completing the hardware rebuild I ran a scrub (since it had been 7 days and my schedule wasn't set for another 5 ... and I figured it would be a good thing to run a scrub with new hardware). I just checked the Reporting tab the following afternoon and all the graphs are populated. For future readers - try running a scrub after changing hardware.
# zpool scrub tank
and then to check the status later if you close your SSH or GUI shell window
# zpool status
