toadman
- Jun 4, 2013
I'm running 9.3.1 on two servers, one is used to backup the main server. (HW listed below.) For about a year I've replicated 4 datasets daily between the two. I was running out of space on the backup server, so I destroyed the pool, added capacity, and created a new pool with the same name.
I then turned on replication again and ticked "initialize once" in each of the replication tasks. They all gave me a failure message.
So I went ahead and started over. I deleted all of the replication tasks and set them back up again. I double checked the public key from PUSH was in the root of PULL, etc.
It's still not working. However, from the command line I am able to properly execute sending a snapshot over to backup with this:
So I'm wondering if something goofed in whatever configuration the replication script is looking at? Any ideas?
Main server (PUSH):
freenas 9.3.1 (updated via 9.3 STABLE)
AMD 955
ASUS m4A89GTD motherboard
16GB ECC memory
LSI 9211-8i HBA
8 disks configured in 4 mirrored pairs
2x intel gigabit nics
2x realtek nics (not used)
Backup server (PULL)
vm running under esxi 6.0
8GB ECC memory
4 vCPUs (AMD 1100T) (normally runs with only 2)
AMD SB950 SATA controller passed through running AHCI
6 3TB WD RED in RAIDZ2
zfs send pool0/userdata@auto-20150101.0100-1y | ssh -i /data/ssh/replication backupserver.freenas.lan zfs receive backup0/userdata@auto-20150101.0100-1y
Main server (PUSH):
AMD 955
16GB ECC memory
LSI 9211-8i HBA
8GB ECC memory
