I am running 2 FreeNAS machines, each on the latest stable version FreeNAS-9.3-STABLE-201412312006.
I have not been able to get replication working, and would like some guidance.
The primary machine has a zvol that contains VMware VMFS file system. This is iSCSI exported to an ESXi host.
That's been working fine for a few months.
While I've been finding my way around FreeNAS and the underlying systems, I have been doing manual snapshots and transferring those – using send/recv – to a secondary FreeNAS machine. That too has been working fine. The secondary machine has also been used as an iSCSI target to confirm that data is landing OK, and to provide a route for backup outside of the FreeNAS context.
All baby steps, but by and large working fine.
I wanted to automate the send/recv process and so defined a Periodic Snapshot task. This does the job.
Snapshots are being automatically created every 2 hours, as requested. However, the Replication Task based on the same dataset fails immediately (and repeatedly). The on-screen status and the emailed error messages are jointly saying:
If I try (what I presume is) the manual version of the replication – i.e. send/recv – it works fine, without any changes at all to the setup.
In the Replication Task, on the initial attempt - when all I had on the destination machine was a newly-defined, empty zvol – I set the switches as follows:
I have also tried with Compression disabled. Identical failure message.
Is there some known problem with Replication, or is something mistaken in the route I'm using?
Any advice would be welcome.
Replication <sourceDataset> -> 192.168.218.57:<targetDataset> failed: cannot open '<targetDataset>': operation not applicable to datasets of this type cannot receive new filesystem stream: unable to restore to destination Error 33 : Write error : cannot write compressed block
I have ensured that the iSCSI service is not running on the destination (I've had trouble in the past with send/recv to an active iSCSI target).If I try (what I presume is) the manual version of the replication – i.e. send/recv – it works fine, without any changes at all to the setup.
Recursively replicate and remove stale snapshot on remote side: True
Initialize remote side for once. (May cause data loss on remote side!): True
Replication Stream Compression: lz4(fastest) – default
On subsequent attempts to create a Replication Task, I did not set the “Initialise remote” switch.Initialize remote side for once. (May cause data loss on remote side!): True
