Replication problem scale to core
hescominsoon
I have scale 23.10 as a replication target for my core machine. My core machine had a major failure and died. I've rebuilt my core machine and now I'm trying to get the data that's on scale over the core. However, I keep gain an authentication failed error from scale even though the SSH connection was created successfully and it got the remote key from the core machine. So I'm trying to figure out how to get the data from scale over the core. I can't find anything that says what the authentication failure is. It just tells me authentication failure and won't do the replication. Any ideas where to look?
hescominsoon
I wound up setting up a pull from core to scale as scale refused to connect to core.
