Replication from pool to pool
yoongacme
Hi Guys
Did freenas able to replicate from pool to pool??
because when i replicate a whole pool, i get this error message
"Please move system dataset of remote side to another pool"
Glorious1
It definitely can replicate from pool to pool, I do it daily.
I don't quite understand that error. If I were you, I would move the system dataset to another pool and see if it works. My system dataset is on the sending pool, not the receiving.
WebGUI > System > System dataset
I believe you can do exactly as the error message suggests. Check out the following in the latest version of FreeNAS. Be sure to follow the User Guide for the version you're running.
