Replacing hard drive in pool
ajbrehm
I have a pool of 8 TB size. It consisted of a 8 TB and a 10 TB disk.
I replaced the 8 TB disk with a second 10 TB disk.
This worked so far and the data has been synced as far as I can tell. It took some time.
Now the pool is still shown as degraded because of the missing disk. How can I logically remove the disk?
And the pool size is still 8 TB. How can I extend the pool size to the full (somewhat less than) 10 TB of the two disks?
Thanks,
Andrew
ajbrehm
The problem just solved itself.
I found where I could remove the missing disk ("Status" menu). And once I had removed it, the pool expanded automatically to 9.x TB as wanted.
