Replacing failing drive - State: Unavail
FaxeB
My system:
FreeNAS-9.10.2-U6 (561f0d7a1)
5 x 3 TB raidz2
8 GB RAM
Recently I got the alert: 'ada1 has too many errors'. Since the drive has warranty I ordered an RMA (WD red) and got it fast. The drive was already offline, so when reading https://www.ixsystems.com/documentation/freenas/9.10/storage.html#replacing-a-failed-drive I jumped directly to "shut down the system to physically replace the disk". I did so and when starting it up again the ada1 showed 'UNAVAIL'. After that I've been searching this forum up and down without any success - probably I've done something preventing me from succeeding... So now I'm back at this 'UNAVAIL' state and I'm asking for my next step. Some info:
[root@freenas ~]# zpool status
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0h2m with 0 errors on Tue Apr  2 03:47:23 2019
        freenas-boot  ONLINE       0     0     0
          da0p2     ONLINE       0     0     0
errors: No known data errors
  pool: storage
 state: DEGRADED
status: One or more devices could not be opened.  Sufficient replicas exist for
        the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
   see: http://illumos.org/msg/ZFS-8000-2Q
  scan: scrub repaired 0 in 6h15m with 0 errors on Sun Apr 28 06:15:02 2019
        NAME                                          STATE     READ WRITE CKSUM
        storage                                       DEGRADED     0     0     0
          raidz2-0                                    DEGRADED     0     0     0
            ada0                                      ONLINE       0     0     0
            6753909526819114032                       UNAVAIL      0     0     0  was /dev/ada1
            ada2                                      ONLINE       0     0     0
            ada3                                      ONLINE       0     0     0
            ada4                                      ONLINE       0     0     0
          gptid/5886bff8-6f81-11e9-ab7f-001d60a7173e  ONLINE       0     0     0
[root@freenas ~]# sysctl kern.disks
kern.disks: da0 ada4 ada3 ada2 ada1 ada0
[root@freenas ~]# gpart show ada1
=>        34  5860533101  ada1  GPT  (2.7T)
          34          94        - free -  (47K)
         128     4194304     1  freebsd-swap  (2.0G)
     4194432  5856338696     2  freebsd-zfs  (2.7T)
  5860533128           7        - free -  (3.5K)
[root@freenas ~]# zpool replace 6753909526819114032 /dev/ada1
cannot open '6753909526819114032': name must begin with a letter
I think I'll update the system when I'm back on track, but right now I'd like a hint or two to get there. Thank you!
pro lamer
Your system is not raidz2. It's raidz2 striped with a single drive. If you lose that single drive you would loose the whole pool.
I'd recommend you considered some solution to the above first. The best would be a complete pool rebuild but if not possible then at least add a mirror drive to gptid/5886bff8-6f81-11e9-ab7f-001d60a7173e.
Just be careful not to make things worse.
Sent from my phone
tfran1990
How can you tell just by looking at his zpool status?
he must have use diskmanager when he did the replace and added a single disc mirror on accident?
myoung
The indentation shows which disks are in which vdev. It looks like the raidZ2 vdev came from another system (all the labels are adaX). Then he accidentaly added the new disk as a new vdev through the GUI instead of replacing the bad disk (it has gptid label).
Sent from my phone
He could update to 11.2 and zpool remove the new single disk vdev.
Can you post the output of zpool iostat -v and zpool history storage
FaxeB
Thank you for this rapid response!
[root@freenas ~]# zpool iostat -v
                                           capacity     operations    bandwidth
pool                                    alloc   free   read  write   read  write
freenas-boot                            2.03G  12.3G      1      0  72.1K  5.49K
  da0p2                                 2.03G  12.3G      1      0  72.1K  5.49K
storage                                 5.26T  11.1T     18     70   506K   565K
  raidz2                                5.26T  8.38T     18     53   502K   362K
    ada0                                    -      -      8     18   143K   181K
    6753909526819114032                     -      -      0      0      0      0
    ada2                                    -      -      5     16   131K   181K
    ada3                                    -      -      6     16   162K   181K
    ada4                                    -      -      9     18   174K   181K
  gptid/5886bff8-6f81-11e9-ab7f-001d60a7173e   368M  2.72T      0     16  4.09K   203K
and (this one is long - the old part is attached as file):
[root@freenas ~]# zpool history storage
History for 'storage':
<snip to file>
2018-12-23.00:00:09 zpool scrub storage
2018-12-30.00:00:04 zpool scrub storage
2019-01-06.00:00:11 zpool scrub storage
2019-01-13.00:00:10 zpool scrub storage
2019-01-20.00:00:13 zpool scrub storage
2019-01-27.00:00:11 zpool scrub storage
2019-02-03.00:00:10 zpool scrub storage
2019-02-10.00:00:09 zpool scrub storage
2019-02-17.00:00:09 zpool scrub storage
2019-02-24.00:00:09 zpool scrub storage
2019-03-03.00:00:10 zpool scrub storage
2019-03-10.00:00:11 zpool scrub storage
2019-03-17.00:00:09 zpool scrub storage
2019-03-17.23:04:25 zpool import -o cachefile=none -R /mnt -f storage
2019-03-17.23:04:25 zpool set cachefile=/data/zfs/zpool.cache storage
2019-03-17.23:14:07 zpool import -o cachefile=none -R /mnt -f storage
2019-03-17.23:14:07 zpool set cachefile=/data/zfs/zpool.cache storage
2019-03-24.00:00:13 zpool scrub storage
2019-03-31.00:00:12 zpool scrub storage
2019-04-07.00:00:10 zpool scrub storage
2019-04-14.00:00:09 zpool scrub storage
2019-04-21.00:00:09 zpool scrub storage
2019-04-28.00:00:09 zpool scrub storage
2019-05-01.19:32:31 zfs create -o casesensitivity=sensitive -o aclmode=restricted storage/burken/shared
2019-05-01.19:32:36 zfs set org.freenas:description= storage/burken/shared
2019-05-04.23:21:25 zpool import -o cachefile=none -R /mnt -f storage
2019-05-04.23:21:25 zpool set cachefile=/data/zfs/zpool.cache storage
2019-05-04.23:53:17 zpool online storage 6753909526819114032
2019-05-04.23:59:57 zpool import -o cachefile=none -R /mnt -f storage
2019-05-04.23:59:57 zpool set cachefile=/data/zfs/zpool.cache storage
2019-05-05.00:20:12 zpool online storage 6753909526819114032
2019-05-05.23:17:29 zpool import -o cachefile=none -R /mnt -f storage
2019-05-05.23:17:29 zpool set cachefile=/data/zfs/zpool.cache storage
2019-05-06.00:01:39 zpool add -f storage /dev/gptid/5886bff8-6f81-11e9-ab7f-001d60a7173e
2019-05-06.21:14:42 zpool online storage ada1
2019-05-06.21:53:44 zpool import -o cachefile=none -R /mnt -f storage
2019-05-06.21:53:44 zpool set cachefile=/data/zfs/zpool.cache storage
2019-05-06.22:09:31 zpool import -o cachefile=none -R /mnt -f storage
2019-05-06.22:09:31 zpool set cachefile=/data/zfs/zpool.cache storage
2019-05-08.21:12:27 zpool import -o cachefile=none -R /mnt -f storage
2019-05-08.21:12:27 zpool set cachefile=/data/zfs/zpool.cache storage
  • zpool_history_storage.txt
tfran1990
I just started using freenas when 10.x came out. Has zpool remove been a thing before 11.2?
my guess is yes, but you mentioned updating to 11.2 to do so.
No, he can't--vdev removal only works when all vdevs are either single disks or mirrors--which makes it considerably less useful than it otherwise would have been.
myoung
Oh, dang! I guess that's not an option.
myoung
From 11.2 Release notes (Emphasis mine):
OpenZFS is up-to-date with Illumos and slightly ahead due to support for sorted scrubs which were ported from ZFS on Linux. Notable improvements include channel programs, data disk removal, more resilient volume import, the ability to import a pool with missing vdevs, pool checkpoints, improved compressed ARC performance, and ZIL batching. Note that many of these improvements need further testing so have not yet been integrated into the UI.
myoung
<snip to file>
We can see here that you accidentally added the new disk as a single disk vdev on Monday, 5/6/2019 via the GUI.
...which meant both ignoring the documentation, and bypassing a bunch of warnings.
FaxeB
Thank you for this analysis. Yes, I did a bad command when I was searching for the solution for the initial 'unavail' problem. When I read your answer I don't find any 'unstriping' to raidz1 or back to a degraded raidz2, so I'm open for more ideas. (And if none, I'll prepare for a rebuild.)
myoung
Apparently you can't remove a vdev from a pool which contains a raidz vdev, as @danb35 pointed out above. I think your only good option is to backup and rebuild your pool.
FaxeB
So, when rebuilding why not updating. I already have the disk and RAM, and got this proposal:
Board: Supermicro X9Sri-F
CPU: E5-2630L @ 2 GHz or E5-1620 @ 3,6 GHz
RAM: 8 x 4 GB ECC (PC3-8500-7-10-HP)
Disk: 5 x 3 TB RAIDZ2 WD-red
Network: Dual intel Gigabit LAN based on i350
Any comments?
pro lamer
Better go with 4pcs of 8GB so you have slots available for future
Sent from my phone
FaxeB
Correct, but these 8 x 4 are "for free". That's why I start this way.
Any thought about the CPU choice E5-2630L @ 2 GHz or E5-1620 @ 3,6 GHz ? I read that higher GHz is better for Samba and I don't plan for any encryption or transcoding.
