The other day one of my SSDs dropped from a mirrored volume. They are both Samsung 950 Pro drives
I powered down, tested the SSD using smartctl on another linux machine with a known working cable. It passed smartctl short test with flying colors and no suspicious items on the smart readout. The SSDs are very new, both were installed brand new 8ish months ago and have not gotten hardly any use at all.
I also tested the SATA power cable AND port (modular) on the PSU.
If I run dmesg, I get a bunch of these errors, which also show up during startup:
The missing drive is ada1, I'm not sure why it's showing ada3:ahci31 in the errors. There should be 2 SSDs at the top
smartctl --scan
I'm not finding a whole lot on google for this. Or other tests to perform. Any ideas? Thanks
This is a virtualized environment, all drives are on a passed through intel wellsburg ahci SATA controller. I know, not ideal, but it's been running fine for year. I haven't really touched the server in months. Just happened out of nowhere.
I found similar a report of another user very recently:
https://forums.freenas.org/index.php?threads/what-does-a-nop-flushqueue-message-mean.54736/
And:
https://forums.freenas.org/index.ph...onnect-to-the-volume-detect-by-freenas.54188/
Freenas 9.10.2-U2 (updating to U6 completely breaks my freenas install so I can't upgrade)
GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) ahcich31: Timeout on slot 25 port 0 ahcich31: is 00000000 cs 02000000 ss 00000000 rs 02000000 tfd c0 serr 00000000 cmd 0004d917 (ada3:ahcich31:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00 (ada3:ahcich31:0:0:0): CAM status: Command timeout (ada3:ahcich31:0:0:0): Retrying command ahcich31: Timeout on slot 0 port 0 ahcich31: is 00000000 cs 00000001 ss 00000000 rs 00000001 tfd d0 serr 00000000 cmd 0004c017 (ada3:ahcich31:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00 (ada3:ahcich31:0:0:0): CAM status: Command timeout (ada3:ahcich31:0:0:0): Error 5, Retries exhausted ahcich31: Timeout on slot 11 port 0 ahcich31: is 00000000 cs 00000800 ss 00000000 rs 00000800 tfd c0 serr 00000000 cmd 0004cb17 (ada3:ahcich31:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00 (ada3:ahcich31:0:0:0): CAM status: Command timeout (ada3:ahcich31:0:0:0): Retrying command ahcich31: Timeout on slot 18 port 0 ahcich31: is 00000000 cs 00040000 ss 00000000 rs 00040000 tfd d0 serr 00000000 cmd 0004d217 (ada3:ahcich31:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00 (ada3:ahcich31:0:0:0): CAM status: Command timeout (ada3:ahcich31:0:0:0): Error 5, Retries exhausted ahcich31: Timeout on slot 25 port 0 ahcich31: is 00000000 cs 06000000 ss 00000000 rs 06000000 tfd d0 serr 00000000 cmd 0004d917 (ada3:ahcich31:0:0:0): DSM TRIM. ACB: 06 01 00 00 00 40 00 00 00 00 01 00 (ada3:ahcich31:0:0:0): CAM status: Command timeout (ada3:ahcich31:0:0:0): Retrying command ahcich31: AHCI reset: device not ready after 31000ms (tfd = 00000080) ahcich31: Timeout on slot 27 port 0 ahcich31: is 00000000 cs 08000000 ss 00000000 rs 08000000 tfd 80 serr 00000000 cmd 0004db17 (aprobe0:ahcich31:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 (aprobe0:ahcich31:0:0:0): CAM status: Command timeout (aprobe0:ahcich31:0:0:0): Retrying command ahcich31: AHCI reset: device not ready after 31000ms (tfd = 00000080) ahcich31: Timeout on slot 28 port 0 ahcich31: is 00000000 cs 10000000 ss 00000000 rs 10000000 tfd 80 serr 00000000 cmd 0004dc17 (aprobe0:ahcich31:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 (aprobe0:ahcich31:0:0:0): CAM status: Command timeout (aprobe0:ahcich31:0:0:0): Error 5, Retries exhausted ahcich31: AHCI reset: device not ready after 31000ms (tfd = 00000080) ahcich31: Timeout on slot 29 port 0 ahcich31: is 00000000 cs 20000000 ss 00000000 rs 20000000 tfd 80 serr 00000000 cmd 0004dd17 (aprobe0:ahcich31:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 (aprobe0:ahcich31:0:0:0): CAM status: Command timeout (aprobe0:ahcich31:0:0:0): Error 5, Retry was blocked ada3 at ahcich31 bus 0 scbus33 target 0 lun 0 ada3: <Samsung SSD 850 PRO 256GB EXM03B6Q> s/n S39KNX0HA63503R detached ahcich31: AHCI reset: device not ready after 31000ms (tfd = 00000080) ahcich31: Timeout on slot 30 port 0 ahcich31: is 00000000 cs 40000000 ss 00000000 rs 40000000 tfd 80 serr 00000000 cmd 0004de17 (ada3:ahcich31:0:0:0): SETFEATURES ENABLE RCACHE. ACB: ef aa 00 00 00 40 00 00 00 00 00 00 (ada3:ahcich31:0:0:0): CAM status: Command timeout (ada3:ahcich31:0:0:0): Error 5, Periph was invalidated ahcich31: AHCI reset: device not ready after 31000ms (tfd = 00000080) ahcich31: Poll timeout on slot 0 port 0 ahcich31: is 00000000 cs 00000001 ss 00000000 rs 00000001 tfd 80 serr 00000000 cmd 0004c017 (aprobe0:ahcich31:0:0:0): NOP FLUSHQUEUE. ACB: 00 00 00 00 00 00 00 00 00 00 00 00 (aprobe0:ahcich31:0:0:0): CAM status: Command timeout (aprobe0:ahcich31:0:0:0): Error 5, Retries exhausted ahcich31: Timeout on slot 1 port 0 ahcich31: is 00000000 cs 00000006 ss 00000000 rs 00000006 tfd 80 serr 00000000 cmd 0004c117 (ada3:ahcich31:0:0:0): DSM TRIM. ACB: 06 01 00 00 00 40 00 00 00 00 01 00 (ada3:ahcich31:0:0:0): CAM status: Command timeout (ada3:ahcich31:0:0:0): Error 5, Periph was invalidated (ada3:ahcich31:0:0:0): WRITE_DMA. ACB: ca 00 f8 21 80 40 00 00 00 00 10 00 (ada3:ahcich31:0:0:0): CAM status: Unconditionally Re-queue Request (ada3:ahcich31:0:0:0): Error 5, Periph was invalidated (ada3:ahcich31:0:0:0): Periph destroyed ahcich31: AHCI reset: device not ready after 31000ms (tfd = 00000080) ahcich31: Poll timeout on slot 4 port 0 ahcich31: is 00000000 cs 00000010 ss 00000000 rs 00000010 tfd 80 serr 00000000 cmd 0004c417 (aprobe0:ahcich31:0:0:0): NOP FLUSHQUEUE. ACB: 00 00 00 00 00 00 00 00 00 00 00 00 (aprobe0:ahcich31:0:0:0): CAM status: Command timeout (aprobe0:ahcich31:0:0:0): Error 5, Retries exhausted
![EC1fcFw.png](https://i.imgur.com/EC1fcFw.png)
smartctl --scan
/dev/ada0 -d atacam # /dev/ada0, ATA device /dev/ada1 -d atacam # /dev/ada1, ATA device /dev/ada2 -d atacam # /dev/ada2, ATA device /dev/ada3 -d atacam # /dev/ada3, ATA device /dev/ada4 -d atacam # /dev/ada4, ATA device /dev/ada5 -d atacam # /dev/ada5, ATA device /dev/ada6 -d atacam # /dev/ada6, ATA device /dev/ada7 -d atacam # /dev/ada7, ATA device /dev/ada8 -d atacam # /dev/ada8, ATA device
zpool status pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0h2m with 0 errors on Mon Apr 2 03:47:37 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 ada0p2 ONLINE 0 0 0 ada1p2 ONLINE 0 0 0 errors: No known data errors pool: lightning state: DEGRADED status: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Attach the missing device and online it using 'zpool online'. see: http://illumos.org/msg/ZFS-8000-2Q scan: scrub repaired 0 in 0h2m with 0 errors on Fri Apr 20 17:16:15 2018 config: NAME STATE READ WRITE CKSUM lightning DEGRADED 0 0 0 mirror-0 DEGRADED 0 0 0 gptid/3314a75a-e0e5-11e6-94a9-000c293a029e ONLINE 0 0 0 17822343706091218419 UNAVAIL 0 0 0 was /dev/gptid/334432cb-e0e5-11e6-94a9-000c293a029e errors: No known data errors pool: thunder state: ONLINE scan: scrub repaired 0 in 3h11m with 0 errors on Wed Mar 14 06:11:40 2018 config: NAME STATE READ WRITE CKSUM thunder ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/241dc692-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/24e8bc15-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/25b9f266-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/26894821-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/275eb7c5-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/28270aa2-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 errors: No known data errors
[root@freenas] /dev# zpool online lightning 17822343706091218419 warning: device '17822343706091218419' onlined, but remains in faulted state
[root@freenas] /dev# smartctl -a /dev/ada1 smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: VMware Virtual SATA Hard Drive Serial Number: 01000000000000000001 LU WWN Device Id: 5 000c29 bfddddcd0 Firmware Version: 00000001 User Capacity: 17,179,869,184 bytes [17.1 GB] Sector Size: 512 bytes logical/physical Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ATA/ATAPI-6 T13/1410D revision 0 Local Time is: Mon Apr 23 20:20:50 2018 CDT SMART support is: Unavailable - device lacks SMART capability. A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options. [root@freenas] /dev# smartctl -a -T permissive /dev/ada1 smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: VMware Virtual SATA Hard Drive Serial Number: 01000000000000000001 LU WWN Device Id: 5 000c29 bfddddcd0 Firmware Version: 00000001 User Capacity: 17,179,869,184 bytes [17.1 GB] Sector Size: 512 bytes logical/physical Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ATA/ATAPI-6 T13/1410D revision 0 Local Time is: Mon Apr 23 20:20:55 2018 CDT SMART support is: Unavailable - device lacks SMART capability. SMART Disabled. Use option -s with argument 'on' to enable it. (override with '-T permissive' option) [root@freenas] /dev# smartctl smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org ERROR: smartctl requires a device name as the final command-line argument. Use smartctl -h to get a usage summary [root@freenas] /dev# zpool status pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0h2m with 0 errors on Mon Apr 2 03:47:37 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 ada0p2 ONLINE 0 0 0 ada1p2 ONLINE 0 0 0 errors: No known data errors pool: lightning state: DEGRADED status: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Attach the missing device and online it using 'zpool online'. see: http://illumos.org/msg/ZFS-8000-2Q scan: scrub repaired 0 in 0h2m with 0 errors on Fri Apr 20 17:16:15 2018 config: NAME STATE READ WRITE CKSUM lightning DEGRADED 0 0 0 mirror-0 DEGRADED 0 0 0 gptid/3314a75a-e0e5-11e6-94a9-000c293a029e ONLINE 0 0 0 17822343706091218419 UNAVAIL 0 0 0 was /dev/gptid/334432cb-e0e5-11e6-94a9-000c293a029e errors: No known data errors pool: thunder state: ONLINE scan: scrub repaired 0 in 3h11m with 0 errors on Wed Mar 14 06:11:40 2018 config: NAME STATE READ WRITE CKSUM thunder ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/241dc692-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/24e8bc15-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/25b9f266-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/26894821-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/275eb7c5-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/28270aa2-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 errors: No known data errors [root@freenas] /dev# zpool online /dev/ada1 missing device name usage: online [-e] <pool> <device> ... [root@freenas] /dev# zpool online lightning lightning cannot online lightning: no such device in pool [root@freenas] /dev# zpool online lightning 17822343706091218419 warning: device '17822343706091218419' onlined, but remains in faulted state use 'zpool replace' to replace devices that are no longer present [root@freenas] /dev# zpool status pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0h2m with 0 errors on Mon Apr 2 03:47:37 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 ada0p2 ONLINE 0 0 0 ada1p2 ONLINE 0 0 0 errors: No known data errors pool: lightning state: DEGRADED status: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Attach the missing device and online it using 'zpool online'. see: http://illumos.org/msg/ZFS-8000-2Q scan: scrub repaired 0 in 0h2m with 0 errors on Fri Apr 20 17:16:15 2018 config: NAME STATE READ WRITE CKSUM lightning DEGRADED 0 0 0 mirror-0 DEGRADED 0 0 0 gptid/3314a75a-e0e5-11e6-94a9-000c293a029e ONLINE 0 0 0 17822343706091218419 UNAVAIL 0 0 0 was /dev/gptid/334432cb-e0e5-11e6-94a9-000c293a029e errors: No known data errors pool: thunder state: ONLINE scan: scrub repaired 0 in 3h11m with 0 errors on Wed Mar 14 06:11:40 2018 config: NAME STATE READ WRITE CKSUM thunder ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/241dc692-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/24e8bc15-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/25b9f266-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/26894821-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/275eb7c5-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 gptid/28270aa2-e0f1-11e6-94a9-000c293a029e ONLINE 0 0 0 errors: No known data errors [root@freenas] /dev# smartctl -a /dev/ada1 smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: VMware Virtual SATA Hard Drive Serial Number: 01000000000000000001 LU WWN Device Id: 5 000c29 bfddddcd0 Firmware Version: 00000001 User Capacity: 17,179,869,184 bytes [17.1 GB] Sector Size: 512 bytes logical/physical Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ATA/ATAPI-6 T13/1410D revision 0 Local Time is: Mon Apr 23 20:49:28 2018 CDT SMART support is: Unavailable - device lacks SMART capability. A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options. [root@freenas] /dev# smartctl -a /dev/ada2 smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Samsung based SSDs Device Model: Samsung SSD 850 PRO 256GB Serial Number: S39KNX0HA63496N LU WWN Device Id: 5 002538 d4162c297 Firmware Version: EXM03B6Q User Capacity: 256,060,514,304 bytes [256 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4c SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Apr 23 20:49:32 2018 CDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x53) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 133) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 9 Power_On_Hours 0x0032 097 097 000 Old_age Always - 10298 12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 42 177 Wear_Leveling_Count 0x0013 098 098 000 Pre-fail Always - 67 179 Used_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 0 181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0 182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0 183 Runtime_Bad_Block 0x0013 100 100 010 Pre-fail Always - 0 187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0032 066 053 000 Old_age Always - 34 195 ECC_Error_Rate 0x001a 200 200 000 Old_age Always - 0 199 CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0 235 POR_Recovery_Count 0x0012 099 099 000 Old_age Always - 24 241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 15400954249 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing 255 0 65535 Read_scanning was never started Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
And:
