Drive faulted when trying to resilver
patrickRx
Hello, I had a drive that started giving read and write errors so I warrantied it. When trying to get resilver the drive, it faults with multiple read and write errors. I've tried this multiple times. So apparently not the drive. I've tried with a different cable as well. Can anyone help me begin to troubleshoot this? Here is the output of zpool status.
root@freenas[~]# root@freenas[~]# zpool status data01
  pool: data01
 state: DEGRADED
  scan: resilvered 257G in 0 days 11:48:40 with 0 errors on Tue Mar 10 00:28:06 2020
        NAME                        STATE     READ WRITE CKSUM
        data01                      DEGRADED     0     0     0
          raidz2-0                  DEGRADED     0     0     0
            da0p2                   ONLINE       0     0     0
            da1p2                   ONLINE       0     0     0
            da2p2                   ONLINE       0     0     0
            da3p2                   ONLINE       0     0     0
            da4p2                   ONLINE       0     0     0
            replacing-5             UNAVAIL      0     0     0
              18047286444837006076  OFFLINE      0     0     0  was /dev/da7p1
              da6                   FAULTED      6 9.45K     0  too many errors
Thank you.
hervon
Did you test the new drive before inserting it in the pool ? Might be faulty too. Since you did not respect the forum guidelines about your current hardware it is hard to help much further.
patrickRx
Sorry I clearly missed that step. Hardware is as follows:
CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Motherboard: ASUS P8H77-M LE LGA 1155
Ram: 16GB non-ECC
Drive controller: SAS-9220-8i flashed to interface mode
Drives: 6x Seagate Barracuda 4tb
As for testing the drive, would you recommend running a SMART long test?
Thanks again.
hervon
Long Smart test is a way to go. Also search the forums for disk burn-in test before putting them in pool.
Redcoat
patrickRx
Hello, I did run all the tests in the Fester's Guide with no errors. The SMART results are below. I'm concerned that this in fact a problem with my controller card. I tried with two different cables, and I'm getting read and write errors with no checksum errors on the new drive, same as the old drive. Any other ideas besides buying a new card? Thank you!
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p5 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate Barracuda 3.5
Device Model:     ST4000DM004-2CV104
Serial Number:    ZFN0EC4Y
LU WWN Device Id: 5 000c50 0a48f6b68
Firmware Version: 0001
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5425 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Mar 11 17:53:33 2020 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (    0) seconds.
capabilities:                    (0x73) SMART execute Offline immediate.
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 493) minutes.
Conveyance self-test routine
SCT capabilities:              (0x30a5) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   083   067   006    Pre-fail  Always       -       179112192
  3 Spin_Up_Time            0x0003   099   099   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       2
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   070   060   045    Pre-fail  Always       -       9607330
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       211 (26 15 0)
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       2
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   098   000    Old_age   Always       -       0 0 13
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   073   070   040    Old_age   Always       -       27 (Min/Max 23/29)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       8
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       10
194 Temperature_Celsius     0x0022   027   040   000    Old_age   Always       -       27 (0 23 0 0 0)
195 Hardware_ECC_Recovered  0x001a   083   067   000    Old_age   Always       -       179112192
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       203h+35m+31.700s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       3962422120
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       164740
SMART Error Log Version: 1
No Errors Logged
# 1  Conveyance offline  Completed without error       00%       211         -
# 2  Short offline       Completed without error       00%       211         -
# 3  Extended offline    Completed without error       00%       186         -
Redcoat
I guess, given the time, you didn't yet run badblocks? Anyway, I suggest you might switch ports on your card and try again to see if it's a specific port problem. Maybe switch the slot the card is in also as another test.
patrickRx
Thank you for your response. I did run badblocks, although if you think it was too quick perhaps I did something incorrectly? I used the following command:
badblocks –b 4096 –vws /dev/da6
I have tried both ports on the controller card with two different cables. Unfortunately I only have one PCIE slot long enough on my motherboard. Are there any ways to test the controller card without buying a new one? My one option I can think of would be to use the motherboards SATA slots and see if that solves the problem, however there are only 6 so I would need to move my boot partition to a USB drive first (still supported on FreeNAS?).
Thank you again.
Redcoat
The badblocks line looks fine. My 4TB WD Reds took approx 24 hours per test and it seems yours was shorter...
Your suggestion is an interesting option for a test at least. USB's not preferred these days because of short life-expectancy, but not forbidden.
