Replacing drive in mirror with smaller one
zimon
I have a boot zfspool with 3 mirrored devices. 2 16GB usb drives and one old 128GB SSD.
Unfortunately the SSD just died so I wanted to replace it with another 16GB USB drive (the exact same type of the other already mirrored 2)
But when I try to replace it (in the WebGUI) I get an error that the drive is too small.
Do I need a drive wich is 128GB big? Even if the others are only 16GB?
If so, can I remove the (already removed) SSD from the pool for good and add another 16GB usb mirror?
thanks, hope someone can help me
When did you first install FreeNAS? The EFI system partition size was increased a few months ago, with the practical result that you can't use disks of the same size - they'd need to be 100 MB (or however much) larger. Of course, you can do the whole thing manually, but that's a pain in the ass.
zimon
ah ok now I understand you, I guess.
So normally replacing the 128GB disk with a 16GB flash drive should work since the mirror is only 16GB right?
Well I have FreeNAS-9.10.2-U1 (86c7ef5) I did not update a long time ago (I think) so that should actually work, or am I mistaken?
Can't I just kick out the already removed disk so that I just have a mirror with 2 disks? And then I could just add another 16GB drive right?
Hmm, 9.10 is much older than the change I mentioned. Can you post the exact error you get?
zimon
I tried two different usb flash drives where one was completely unused and new.
Nov 20 21:55:00 theVault GEOM: da2: the primary GPT table is corrupt or invalid.
Nov 20 21:55:00 theVault GEOM: da2: using the secondary instead -- recovery strongly advised.
Nov 20 21:55:01 theVault notifier: 32+0 records in
Nov 20 21:55:01 theVault notifier: 32+0 records out
Nov 20 21:55:01 theVault notifier: 33554432 bytes transferred in 3.322055 secs (10100504 bytes/sec)
Nov 20 21:55:05 theVault notifier: dd: /dev/da2: short write on character device
Nov 20 21:55:05 theVault notifier: dd: /dev/da2: end of device
Nov 20 21:55:05 theVault notifier: 33+0 records in
Nov 20 21:55:05 theVault notifier: 32+1 records out
Nov 20 21:55:05 theVault notifier: 33595392 bytes transferred in 3.933975 secs (8539808 bytes/sec)
Nov 20 21:55:12 theVault ZFS: vdev state changed, pool_guid=15607185754263842137 vdev_guid=2704911025820488020
Nov 20 21:55:14 theVault manage.py: [middleware.exceptions:37] [MiddlewareError: Failed to attach disk: cannot replace 17602617589208774497 with da2p2: device is too small
Nov 20 21:55:15 theVault manage.py: [rollbar:1265] Got unexpected status code from Rollbar api: 403
Response:
  "err": 1,
  "message": "access token not found: caf06383cba14d5893c4f4d0a40c33a9"
Nov 20 21:55:15 theVault manage.py: [rollbar:1097] Exception while posting item ApiError(u'access token not found: caf06383cba14d5893c4f4d0a40c33a9',)
  File "/usr/local/lib/python2.7/site-packages/rollbar/__init__.py", line 1095, in _send_payload
	_post_api('item/', payload, access_token=access_token)
  File "/usr/local/lib/python2.7/site-packages/rollbar/__init__.py", line 1138, in _post_api
	return _parse_response(path, SETTINGS['access_token'], payload, resp)
  File "/usr/local/lib/python2.7/site-packages/rollbar/__init__.py", line 1274, in _parse_response
	raise ApiError(json_data.get('message') or 'Unknown error')
ApiError: access token not found: caf06383cba14d5893c4f4d0a40c33a9
Nov 20 21:55:42 theVault manage.py: [freeadmin.navtree:577] Couldn't retrieve http://192.168.188.25/plugins/resilio/6/_s/treemenu: timed out
zimon
any help is highly appreciated!
Can't I even just remove the "already removed" drive from the pool so that I have a working pool with 2 mirrored drives? That should be possible right?
Yeah.
zimon
So then I just could remove it, and attach one new drive to the pool via the WebGUI, correct?
The detachment of the old (already removed) drive is only possible via CLI right? I could not find anything in the WebGUI
I haven't really tried it, but the option might still be there, if the disk is still a part of the pool.
