adrianwi
- Oct 15, 2013
I have a small pool with 2 mirrored 500GB SSDs for my jails and databases. I wanted to put some VM zvols on there too, and given the price of SSDs thought I'd upgrade them to 1TB drives.
I've had a quick look at the new manual, but can't find anything that explains this like the old manual did. Am I just not looking hard enough?
Is it just a case of going into Storage > Pools and then clicking the settings cog. From their selected Status, and against one of the drives click the 3 dots and Replace. I can then replace the drive (how do I work out which is which?) and let it resilver and then repeat for the other drive. Once that has resilvered, I can run Expand Pool?
Thanks
Thanks
