Replace zfs disk after disk fault
schrope
after reading hours in forums for a solution and testing around, I hope someone can help me.
I have a RAIDZ2 with 5 SAS disks. Now one is fault and i wanted to replace it. So I got to GUI and set the fault one offline. Shut the system down and installed the new one.
        zfsZ2                                           DEGRADED     0     0     0
          raidz2-0                                      DEGRADED     0     0     0
            gptid/7f72428a-1deb-11e9-8fe8-0fb6b5299048  ONLINE       0     0     0
            15496530577974674740                        OFFLINE      0     0     0  was /dev/gptid/82e24d0f-1deb-11e9-8fe8-0fb6b5299048
            gptid/86b25b24-1deb-11e9-8fe8-0fb6b5299048  ONLINE       0     0     0
            gptid/8ab9e4d9-1deb-11e9-8fe8-0fb6b5299048  ONLINE       0     0     0
            gptid/8e600595-1deb-11e9-8fe8-0fb6b5299048  ONLINE       0     0     0
Back in the GUI I pressed the replace button but got the following message:
Request Method:     POST
Request URL:     http://192.168.0.103/storage/zpool-zfsZ2/disk/replace/15496530577974674740/
Software Version:     FreeNAS-11.1-U7 (b45bfcf29)
Exception Type:     MiddlewareError
Exception Value:
[MiddlewareError: Unable to GPT format the disk "da5": gpart: geom 'da5': File exists
Exception Location:     ./freenasUI/middleware/notifier.py in __gpt_labeldisk, line 380
Server time:     So, 19 Jul 2020 12:23:39 +0200
Traceback
Environment:
Traceback:
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner
  42.             response = get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response
  249.             response = self._get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response
  178.             response = middleware_method(request, callback, callback_args, callback_kwargs)
File "./freenasUI/freeadmin/middleware.py" in process_view
  162.         return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
  23.                 return view_func(request, *args, **kwargs)
File "./freenasUI/storage/views.py" in zpool_disk_replace
  785.             if form.done():
File "./freenasUI/storage/forms.py" in done
  2305.             passphrase=passfile
File "./freenasUI/middleware/notifier.py" in zfs_replace_disk
  1008.         self.__gpt_labeldisk(type="freebsd-zfs", devname=to_disk, swapsize=swapsize)
File "./freenasUI/middleware/notifier.py" in __gpt_labeldisk
  380.                 raise MiddlewareError(f'Unable to GPT format the disk "{devname}": {error}')
Exception Type: MiddlewareError at /storage/zpool-zfsZ2/disk/replace/15496530577974674740/
Exception Value: [MiddlewareError: Unable to GPT format the disk "da5": gpart: geom 'da5': File exists
Request information
GET
No GET data
POST
Variable     Value
__all__     ''
force     'on'
replace_disk     'da5'
__form_id     'form_ZFSDiskReplacementForm'
FILES
No FILES data
COOKIES
Variable     Value
csrftoken     '********'
fntreeSaveStateCookie     'root%2Croot%2F60%2F123%2Croot%2F60%2F134%2Croot%2F211%2Croot%2F60%2F61%2Croot%2F187%2Croot%2F44%2Croot%2F28%2F41%2Croot%2F28%2F38'
sessionid     '9sh2o34zb2j5ii1b0hus4s6pkug9smhe'
META
Variable     Value
I tried to wipe the disk but nothing helped.
One thing seems trange, that before i installed the new drive, the fault one was on da0 and now it, I installed the new drive in the same bay, it is da5.
Could that be the problem?
Thanks in advance for help!
Peter
schrope
Hi!
So I worked through this thread, dd worked as mentioned in the thread, but still get the same errors if I tryed to replace the disk.
[MiddlewareError: Unable to GPT format the disk "da5": gpart: geom 'da5': File exists]
Maybe someone has another idea?
Is it possible to change the "drive-letter" from da5 to da6 or something? I guess somewere in freenas the old da5 is existing and now it's not possible to format this existing and maybe used drive.
