removing stripe from an old drive
fanni
HJI got an older drive that i need to use for a little project i'm working on
it used to be used set up in stripe on trueness set up i was using a the time i have since replaced the trueness machine and built a new one i need this 4thb drive in a desktop machine running windows but is only showing up as 1.63 TB
when plugged into my trueness set up it shows it as 3.63 TB but when i try to create a pool it is only giving me the option to create stripe vedv data,
How do i go about getting it back to it's full capacity to show in a windows machine
any help greatly appreciated.
Samuel Tai
You should be able to reclaim the full capacity by just creating a new GPT partition table on the Windows machine, if you don't need the data on the drive any more.
fanni
Hi it won't do anything other than show me 1.64 TB of space no matter what i do but true-as still shows full size
Have tried eases portion master as well and that just shows 1.64
pschatz100
Windows has tools to delete partitions, wipe and reformat drives. You need to use those tools to reformat a ZFS disk for Windows. You cannot do it from TrueNAS. If you know somebody who is familiar with these administrative tasks, they can help you.
Good luck.
