Remove Virtual Machines via CLI?
kazjim
G'day team, crazy situation has occurred . . .
Yesterday I attempted to add a NVS300 GPU to my server, and pass it through to a VM to use for Docker.
Things didn't go well, and I tried to roll the changes out, but now, anytime I even try to EDIT the VM, the console hangs, and the CLI via Putty (SSH) becomes unresponsive. (Even NFS Shares hang)
So, I'd like to delete the VMs and rebuild what I need (Docker-compose, so no issues there.... )
So, is it possible to delete or edit the VMs from the CLI ?
Thanks!
Details : Homebuilt server 1151 i7 /64GB Ram / Dell H310 (IT Mode)/ 8 x 4tb drives.
Kris Moore
SVP of Engineering
Administrator
If you are using SCALE you can run the "cli" app, and then use something like this:
Run "service vm query" first to get a list of the VMs and their ID's.
kazjim
Thanks, have just tried that, and it also froze the system.
Oddly, an error did appear on the screen though.
kazjim
Thanks, have just tried that, and it also froze the system. Oddly, an error did appear on the screen though. View attachment 53052
Edit - physically went to server and checked screen, and it was mentioning that boot-pool had uncorrectable errors.
I ended up hard-resetting the box and think i'll jsut have to rebuild from backup config.
Thanks
titust1
I am trying the same thing to delete all traces of an old unused VM, but I can't. This VM had the drive on a Pool that does not exist anymore.
I get this
[diskstation]> service delete 1
Error: This system does not support virtualization.
Any idea?
If I want to delete it in the GUI, I get this:
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 175, in call_method
    result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1257, in _call
  File "/usr/lib/python3/dist-packages/middlewared/service.py", line 942, in delete
    rv = await self.middleware._call(
  File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1129, in nf
    res = await f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1261, in nf
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vms.py", line 391, in do_delete
    await self.middleware.run_in_thread(self._check_setup_connection)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1172, in run_in_thread
    return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1169, in run_in_executor
  File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/connection.py", line 64, in _check_setup_connection
    self._check_connection_alive()
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/connection.py", line 57, in _check_connection_alive
    self._system_supports_virtualization()
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/connection.py", line 54, in _system_supports_virtualization
    raise CallError('This system does not support virtualization.')
middlewared.service_exception.CallError: [EFAULT] This system does not support virtualization.
