Remote VNC freezing after xx seconds
truefriend-cz
On TrueNAS Core (only Core... on Scale is not problem) in VM machine (Windows) after runnin in VNC tab in browser after xx (20-90 sec.) freezing all mouse and keyboards access.
If enabling RDP on VM OS and connected to RDP IP+PORT i have problem... disconnected from remote deskotop. And reconnect is not i can (lost connection).
How i can fix this?
Tested on:
TrueNAS CORE
On TrueNAS Scale is working ok.
Are you using the Virtio Network adapter with the drivers from Fedora?
In that case, you're almost certainly set up to suffer from the known issue of network instability with the default driver.
example: https://www.truenas.com/community/t...dows-updates-not-working-in-truenas-vm.89990/
You might also want to do a bit of additional searching as I recall something about the latest virtio drivers being no good and needing to use something like version 180 instead of 219 or something... I think this version is good: https://fedorapeople.org/groups/vir...o/virtio-win-0.1.185-2/virtio-win-0.1.185.iso
This thread may help a little... still watch out for the versions as I mentioned above.
