Hi, newish to FreeNAS but loving it so far, just got my first VM up and running on my box which is FreeNAS 11.3 u2. Installed Ubuntu 18.04.4 and it all seems to work great, but after a few seconds to one minute or so, I lose the ability to control my mouse through the built-in VNC (which I think is bhyve?) - I can still control the keyboard and therefore log in with my user/pw which works. Can't do much beyond that as I don't know how to access cmd line, nor can I control mouse. I can restart the VM and it will work again, but then stop every time. I can still see the mouse cursor, and then my VNC mouse cursor (the x) and at first they keep up with one another, then the ubuntu mouse cursor just stops. Sorry to ramble a bit.
I can't seem to connect a 3rd party VNC viewer (have tried both RealVNC and TightVNC) as they report connect ended unexpectedly and no connection parameters, respectively. I am guessing this is a security issue, unsure how to fix this as well.
I have observed a couple threads on 11.3 issues with Ubuntu and VM's in general as seen below, although they aren't exactly my issue either...
www.ixsystems.com
www.ixsystems.com
Could this be contributing to my issue?
Any help to either of these issues (mouse, or 3rd party VNC connection) would be very much appreciated. Thanks!
bhyve ubuntu 18.04.4 crashing in with kernel 4.15.0-96
After updating to latest freenas my ubuntu VMs also got rebooted, and the latest kernel initiated. This kernel does boot, but very shortly it reports write errors, and become unresponsive. After some fidling i found that if i boot with kernel 4.15.0-91 everything seems to work as it should. I...
Ubuntu VM do not work after 11.3 upgrade
Hi I am fairly new with Freenas and recently I upgraded to 11.3 (thought this was a minor thing… my mistake), everything seems to be working except bhyve. I had an Ubuntu Desktop 18.04 LTS VM running, but after the upgrade, it does not come farther than the GRUB menu on start-up. Whatever I...
