Remote Replication Error
The_Elder
Dear Forum Members.
I am at my wits end and I will appreciate your help.
I have two Truenas Servers - a local and a remote one (on a static ip address). The remote runs Truenas 13.0 while the local runs TrueNAS-12.0-U7. I am running the ssh task on the remote and has changed the ssh port to xxxx. On the remote router, I have configured an external port yyyy to be forwarded to the xxxx port of the remote NAS.
I am trying to set up replication task from the local NAS to the remote. I have run the SSH keypairs and generated both the private and public keys. When i try to establish a replication task, I am faced with two options, each posing a different challenge:
Option 1: Manual ssh connection
  • I populated the host with the remote static ip address
  • changed the port from 22 to yyyy
  • select a private key i had established from the ssh keypairs and then press "Create SSH connection"
It gives me the following error:
"[EFAULT] ssh-keyscan failed: getaddrinfo https://aaa.aaa.aaa.aaa: Non-recoverable failure in name resolution getaddrinfo https://aaa/aaa/aaa/aaa: Non-recoverable failure in name resolution getaddrinfo https://aaa.aaa.aaa.aaa: Non-recoverable failure in name resolution"
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 138, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1213, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/keychain.py", line 525, in remote_ssh_host_key_scan
raise CallError(f"ssh-keyscan failed: {proc.stderr}")
middlewared.service_exception.CallError: [EFAULT] ssh-keyscan failed: getaddrinfo https://aaa.aaa.aaa.aaa: Non-recoverable failure in name resolution
getaddrinfo https://aaa,aaa,aaa,aaa: Non-recoverable failure in name resolution
getaddrinfo https://aaa.aaa.aaa.aaa Non-recoverable failure in name resolution
Option 2: semi-automatic
  • put in my root password (at the same time enable root password logging on the remote server)
  • select a private key I had established from the ssh keypairs and then press "Create SSH connection"
"[EFAULT] Unable to connect to remote system: timed out"
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/keychain.py", line 571, in remote_ssh_semiautomatic_setup
client = Client(os.path.join(re.sub("^http", "ws", data["url"]), "websocket"))
File "/usr/local/lib/python3.9/site-packages/middlewared/client/client.py", line 283, in __init__
self._ws.connect()
File "/usr/local/lib/python3.9/site-packages/middlewared/client/client.py", line 124, in connect
rv = super(WSClient, self).connect()
File "/usr/local/lib/python3.9/site-packages/ws4py/client/__init__.py", line 216, in connect
self.sock.connect(self.bind_addr)
File "/usr/local/lib/python3.9/ssl.py", line 1342, in connect
self._real_connect(addr, False)
File "/usr/local/lib/python3.9/ssl.py", line 1329, in _real_connect
super().connect(addr)
socket.timeout: timed out
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1224, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1128, in run_in_executor
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 979, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/keychain.py", line 573, in remote_ssh_semiautomatic_setup
raise CallError(f"Unable to connect to remote system: {e}")
middlewared.service_exception.CallError: [EFAULT] Unable to connect to remote system: timed out
Samuel Tai
This is already addressed in the Release Notes for 13:
By default, TrueNAS 12 cannot initiate a replication to or from TrueNAS 13 due to an outdated SSH client library. Allowing replication to or from TrueNAS 13 to TrueNAS 12 requires allowing ssh.rsa algorithms. See OpenSSH 8.2 Release for security considerations. Log into the TrueNAS 13 system and go to Services->SSH. Add the SSH Auxiliary Parameter: PubkeyAcceptedAlgorithms +ssh-rsa.
Samuel Tai
Have you tried SSHing manually to the remote 13 system? Did you add the SSH Auxiliary parameter on the 12 side or the 13 side? It has to be on the 13 side.
The_Elder
Yes, I am able to ssh into the remote machine. From the shell of the local machine, using root ssh -p xxxx user@xxx.xxx.xxx.xxx and once I supplied the password, i am in. Additionally from the local machine, I have set up passwordless ssh into the remote and it works.
The_Elder
I added the auxiliary
I added the parameter on the 13 side - the remote machine.
To eliminate the 12/13 debacle, I have now updated the local machine to 13 and I am still having the same errors.
The_Elder
I believe there are Experts on this forum that have done this replication across systems severally. Kindly help, if you could, as I am truly at my wits end in getting this done.
I can ssh into the remote TrueNAS but I can't simply get the local NAS to replicate to the remote. I also tried replicating from the remote to the local, I have similar issues.
Please assist a newbie and your kindness will not go unnoticed.
