Remote access n emby
Tito2050
Hello guys new to Freenas I’m stuck @ getting my Freenas to remote from anywhere will not work also as for emby plug-in as well no luck with remote thanks
If you're serious about wanting help (and it appears you're not based on the almost complete lack of information in your post), you'll need to be clearer about what you have (hardware and setup... check the Forum Rules at the top of the page, including versions of things like "Freenas"), the things you've tried so far and what exactly isn't working ("getting my Freenas to remote from anywhere" isn't accurately describing anything).
If you're looking to be pointed in the right direction, search for "reverse proxy" and "port forward" and do a lot of research about https and security if you don't want to invite the whole internet to look at your stuff.
