Regular Crash/Kernel Panic - Help
Moss_Cadu
We have a freenas system:
FreeBSD 10.3-STABLE #0 r295946+1805185(9.10.2-STABLE):
CPU: Intel(R) Xeon(R) CPU E5-2609 v3 @ 1.90GHz (1900.04-MHz K8-class CPU)
real memory = 36507222016 (34816 MB)
avail memory = 33126821888 (31592 MB)
on a supermicro X10DRH-iT
for a while 23rd feb to 24th feb it has been crashing and restarting several times.
attached are log files from the system but they share a similar message
Fatal trap 12: page fault while in kernel mode
cpuid = 5; apic id = 0a
fault virtual address = 0x20
fault code = supervisor read data, page not present
instruction pointer = 0x20:0xffffffff80395503
stack pointer = 0x28:0xfffffe0a8d14f890
frame pointer = 0x28:0xfffffe0a8d14f8a0
code segment = base 0x0, limit 0xfffff, type 0x1b
= DPL 0, pres 1, long 1, def32 0, gran 1
processor eflags = interrupt enabled, resume, IOPL = 0
current process = 6 (arc_reclaim_thread)
this forum post reports something similar with an arc_reclaim_thread page fault.
https://forums.freenas.org/index.ph...ode-current-process-arc_reclaim_thread.38259/
It's in production so I haven't had the scheduled downtime to do the memory test.
Is there anything else that we could do to diagnose the issue?
  • textdump.tar.0.gz
  • textdump.tar.1.gz
  • textdump.tar.2.gz
  • textdump.tar.3.gz
  • textdump.tar.4.gz
  • messages.txt
Moss_Cadu
okay I have put /var/log/messages on the main post but I believe it has been rotated on the 28th
DrKK
FreeNAS Generalissimo
I'd be interested in knowing what the resolution to this is. Have you verified your install? Should be somewhere in the System->update part of the GUI.
Moss_Cadu
I've done the verification scan and the UI claims it's the files were verified successfully. (again attached to the main post)
DrKK
Oh I'm sorry, I missed that you already did that.
DrKK
Made a few calls. I am told that if the address reported for the trap 12 changes, then you almost certainly have a hardware issue. If the address is always the same, then, it's likely a bug.
Moss_Cadu
Well the four crashes I have on file all have the same pointer addresses......
cpuid = 2; apic id = 04
cpuid = 3; apic id = 06
cpuid = 0; apic id = 00
Moss_Cadu
I've run a memory test and its come clean and then we had another crash with the same pointer addresses
Dump files attached.
**edit attached /var/log/messages
  • msgbuf.txt
  • textdump.tar.last.gz
  • info.last.txt
  • messages.txt
D
dlavigne
Guest
If you haven't already, it is worth creating a bug report at bugs.freenas.org. Post the issue number here.
Moss_Cadu
The issue is persisting and I haven't had any more dump files created since the 5th of march. Has anyone got expertise in reading the dmesg log from this box?
  • dmesg.txt
