Reflections to Plex FreeNAS build
h3nk3t
I'm going to build my own server with these components:
Processor : Intel Xeon E3-1275v6 3,8GHz Socket 1151 Box
https://www.prisjakt.nu/produkt.php?p=4132945
Motherboard :
Supermicro X11SSH-LN4F
https://www.prisjakt.nu/produkt.php?p=4012473
Chassi
: SilverStone CS380
Ram : Kingston ValueRAM DDR4 PC19200/2400MHz ECC CL17 16GB
https://www.prisjakt.nu/produkt.php?p=3695537
PSU : Corsair RM650X 650W
https://www.prisjakt.nu/produkt.php?p=3330351
Disks : 4x WD Red WD40EFRX 64MB 4TB
https://www.prisjakt.nu/produkt.php?p=2167793
I really need ideas and thoughts from you guys.
I will use it for Plex server. It should be future proof with 4k streaming. Most material is in 1080p thou. maybe 4 streams at the same time. I will also download a lot of files 24/7. I think I will run som VM's on it. Different Linux OS's.
It will also be connected to OpenVPN service 24/7. I really don't wanna loose to much bandwith. 250Mbit/100Mbit
Any particular thoughts of my choice of build parts (compatibility, power consumption, speed etc.) I would really appreciate advices from anyone
THANK YOU ALL ESPECIALLY THE DEVS FOR MAKING SO MUCH EFFORT
Chris Moore
Do you intend to say that you are thinking of building with those parts? If you already bought them and are determined to use them, what else is there to say?
h3nk3t
Sorry for my bad language. I'm planning to build with these parts.
But first I wanna check with more experienced FreeNAS builder + and - with My way of thinking.
Chris Moore
I like it. You should be good with all those components and you can always upgrade the RAM in the future if you feel that it is warranted.
I have a Xeon E3 that is a couple generations older and it has handled 3 transcodes without a problem. I am sure that the one you have chosen will be fine.
Maelos
I am looking between the X10 and X11 boards and thier respective CPUs. While my req are not as demanding as yours, I hope to hear how your build performs so I can get a better guage on what I may need.
