Hello
I wish to use the recycle bin with CIFS shares. The recycle bin seems to work however there are only folders in the bin, there are absolutely no files. So it is basically useless.
I only have this problems with one volume ZFS, the others work fine.
If I turn off the export recycle bin it stops making the folders and if restarted it makes the folders in the recycle once again.
The same problem has occurred with current version 8.3.1 and older version 8.2.
Can some one help me to get the files to also appear in the recycle folder.
Thank you
Simon
Thank you
Simon
