Recovering encrypted zpool after previous TrueNas usb device failed.
darkcloud784
So my USB drives (mirrored) both died within the past 24 hours (unsure how they both died at the same time but they did). I have one zpool that is unencrypted and another that is encrypted. I have re-installed truenas core 12 on another media and imported the zpool that is unencrypted but I am unable to import the encrypted one. I have tried uploading the .tar config to system->general but it says "
Error:[/B] [EFAULT] The uploaded file is not valid: local variable 'numsouth' referenced before assignment".
I've also tried using the pwenc_secret provided to import the zpool but it fails to attach.
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 361, in run
    await self.future
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 399, in __run_body
    rv = await self.middleware.run_in_thread(self.method, *([self] + args))
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
    return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
  File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 977, in nf
    return f(*args, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/disk_/encryption_freebsd.py", line 49, in decrypt
    raise CallError(f'The following devices failed to attach: {", ".join(failed)}')
middlewared.service_exception.CallError: [EFAULT] The following devices failed to attach: gptid/6701f550-9c63-11ea-909f-9c5c8e54ad71, gptid/6659781f-9c63-11ea-909f-9c5c8e54ad71, gptid/66f529cc-9c63-11ea-909f-9c5c8e54ad71, gptid/66d62e51-9c63-11ea-909f-9c5c8e54ad71, gptid/44ff316f-0bda-11ea-ab98-9c5c8e54ad71, gptid/42f4e17a-0bda-11ea-ab98-9c5c8e54ad71, gptid/4195e4e2-0bda-11ea-ab98-9c5c8e54ad71, gptid/402e68d2-0bda-11ea-ab98-9c5c8e54ad71, gptid/3e6f5d8f-0bda-11ea-ab98-9c5c8e54ad71, gptid/3c15fe91-0bda-11ea-ab98-9c5c8e54ad71, gptid/39321760-0bda-11ea-ab98-9c5c8e54ad71, gptid/a3b79919-9dec-11ea-8f4f-9c5c8e54ad71
What am I doing wrong here? Is there a way for me to recover my encrypted pool?
darkcloud784
I reposted this in Freenas help and support as it may fit there better.
