victorhooi
 - Mar 16, 2012
I have a machine running FreeNAS 11.2-U3.
I have a 6-drive ZFS pool on the machine.
I previously had some Bhyve instances setup on this machine - however, I can't see them now, so I suspect at some point I had to reinstall FreeNAS and I'm simply re-imported the ZFS pool.
When I do "zfs list", I see two lines ("freenas-torrent-manual and freenas-torrent-ne8r4s) which I believe are the zvols associated with those Bhyve VMs:
From memory, they should be running Ubuntu 18.10.
Firstly - is there some way I can confirm from the above that these are indeed ZVOLs, and that they are Bhyve VM disks?
Secondly, is there some way I can re-create a new Bhyve instance to use those disks, or even just read data from those disks to recover it?
Thanks,
Victor
datastore-naulty-place/documents 7.13T 6.60T 7.13T /mnt/datastore-naulty-place/documents datastore-naulty-place/freenas-torrent-manual 581G 6.90T 272G - datastore-naulty-place/freenas-torrent-ne8r4s 1.33T 6.65T 1.29T - datastore-naulty-place/iocage 4.49M 6.60T 3.65M /mnt/datastore-naulty-place/iocage datastore-naulty-place/iocage/download 141K 6.60T 141K /mnt/datastore-naulty-place/iocage/download datastore-naulty-place/iocage/images 141K 6.60T 141K /mnt/datastore-naulty-place/iocage/images datastore-naulty-place/iocage/jails 141K 6.60T 141K /mnt/datastore-naulty-place/iocage/jails datastore-naulty-place/iocage/log 141K 6.60T 141K /mnt/datastore-naulty-place/iocage/log datastore-naulty-place/iocage/releases 141K 6.60T 141K /mnt/datastore-naulty-place/iocage/releases datastore-naulty-place/iocage/templates 141K 6.60T 141K /mnt/datastore-naulty-place/iocage/templates datastore-naulty-place/photos 310G 6.60T 310G /mnt/datastore-naulty-place/photos datastore-naulty-place/software 798M 6.60T 798M /mnt/datastore-naulty-place/software datastore-naulty-place/synology 5.58T 6.60T 5.58T /mnt/datastore-naulty-place/synology datastore-naulty-place/videos 419G 6.60T 419G /mnt/datastore-naulty-place/videos
Thanks,
Victor
