I have a server that I was booting from USB to load FreeNAS and the USB key got damaged. Is there a way to create a new USB boot key and have FreeNAS load the existing configuration of the system?
Generally with defaults without a backup of the config, no. In the case you have placed you system dataset on a pool other than your boot pool, yes. you can recover a copy of the config.
Save Config: save a backup copy of the current configuration database in the format hostname-version-architecture to the computer accessing the administrative interface. Saving the configuration after making any configuration changes is highly recommended. FreeNAS® automatically backs up the configuration database to the system dataset every morning at 3:45. However, this backup does not occur if the system is shut down at that time. If the system dataset is stored on the boot pool and the boot pool becomes unavailable, the backup will also not be available. The location of the system dataset can be viewed or set using System ‣ System Dataset
You should be able to boot to a fresh install, mount the existing pool and copy off the .db file to restore from.
Feel free to log a bug against the docs if you think so. But why does it need to be there? When you go to the System Dataset page, you'll see that it's set to your pool.
When I originally installed FreeNAS this was not the case (for me) so I assumed that the system data set would "happily" live on the boot pool until moved.
Looks like you can ! Going to try this this AM ..
Happy to report that it worked -- now the boot usb is mirrored with another 16G USB stick ... --- too easy .... !!!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
