Reconfigured Networking lost WebGUI
david74
Been running version 9.21 for quite a while now which has been a very smooth experience. I actually run it on hyper-v and this again has not caused any problems.
I recently had problems with Hyper-V networking and ended up reinstalled/refreshing Windows - this got round the hyper-v network problem. During the process a new virtual Nic got assigned to the Hyper-V VM.
I now can't use the WebUI - it doesn't load.
If I try Option 7 and reset the credentials which does work the WebGUI still doesn't appear.
The iSCSI shares are available though as is the Console Shell.
What could I check to resolve the WebGUI connection.
Why wouldn't you just use the network configuration option in the console menu?
