Hi there.
So I'm putting together a system with the goal of running FN along with others as vms on esxi.
I've installed an lsi 9211-8i card which I've flashed to IT mode. Currently, two spinning drives are connected to the lsi card which will be passed through to FN. I think that is good to go.
I also have two identical ssds for the esxi install and vm storage which are connected to the mb ports. I was originally planning on using one ssd to install esxi on and maybe the FN vm, and using the other ssd for all other vms. However, I'd like to have some protection against an ssd failure. I thought it may be a good idea to raid 1 the ssds and put esxi and vms on that, but I'd have to (I think) use the mb raid feature to do that which of course is a bad idea in general.
What would you do with this setup to have a safety against an ssd failure? Is there an automatic solution here without having to manually backup esxi/vms every so often?
I appreciate your input :)
Thank you
Thank you
