I'm looking at rebuilding an old FreeNAS box that I haven't been using in a few years. (Last I looked, it was still called FreeNAS!) I'm trying to catch up with what's changed, primarily going though the FreeNAS TrueNAS community hardware guide, but I still have some questions.
Boot SSDs:
If I understand correct, the current install needs no more than 8 GB of space. This would be a moot point, but is extra space good for anything?
Also, are there any SSDs in particular to avoid? I'm looking at some secondhand Samsung PM871s, or Kingston drives off eBay. (Which are 120/128 GB in size, hence the moot point above.)
HBAs:
I remember that it used to be a thing that the firmware on the HBA had to "match" the version of FreeNAS. Is that still a thing? What firmware version should I have on the card?
Right now I have an IBM M1015 reflashed to IT mode (not sure on FW version). With this build I'm thinking of mounting the drives in an external rack - the casing the system was originaly in was terrible for ventilation and thermals. I'm thinking that gives me two options: Either stick wtih my current card and run the SAS cables out through an unused slot, or I could pick up an 8e HBA. I've seen 9200 and 9207 based cards on eBay, the only difference apparently is that the former is PCIe 2.0 and the latter PCIe 3.0. I should, in theory, be safe running the 9207 in a PCIe 2.0 motherboard, but has anyone heard anything to the contrary?
An 8e card also means I'd pick up a two port SFF-8088 to SFF-8087 adapter off eBay (and a pair of cables to match). I would have thought they're pretty simple things, so they should be safe to use. Again, if anyone has heard otherwise, I'd like to hear your experiences.
The rest of it:
I think I can reuse the rest of the hardware. The motherboard is (I think) an Intel S1200KP, 8 GB ECC RAM, and possibly an ECC supporting i3. I remember trying to be as through as I could in having a working ECC setup back then. Performance isn't an issue for me as I'm not going to use this for anything that would need it. Certainly nothing important. It's more a case of wanting to make use out of what would otherwise continue to be lying around.
One last question: How different is TrueNAS from FreeNAS? Are there any significant changes that I need to take into account?
Also, if there's something I've missed or need to think about, let me know!
Boot SSDs:
HBAs:
The rest of it:
