simple_Robi
- Feb 15, 2024
Hi to everyone and thanks to who will have the patience to help me.
I built my brand new NAS a couple of monthes ago (see below for my current hardware and software setup).
Everything went smooth during the building phase, even installation went smoothly.
Till a couple of weeks ago, everything worked perfectly. I think the bad event that broke my system was a black out that cut the power for like 2 hours while I was sleeping and my UPS died.
Here's the first main problem that I am having latly: after some days that my server is on, I have very bad reading and writing speed on SMB: for the first 3/4 seconds, I write/read at 280ish MB/s (I have a 2,5 Gb/s connection between my server and my pc) but than it falls at 2/3 MB/s or sometimes even 100/150 KB/s and it never comes up again.
It doesn't matter if the file size (I tried 5/10/100/1000 GB) or the device (I tried with my pc - both linux and win - same results with my Mac, my iPhone or iPad).
I can't seems to notice a pattern except that happen after a couple of days being on.
Sometimes it fixes itself after just a reboot, sometimes I have to reboot it several times. One time I had to shut it off completly to make it work.
But here comes the second problem: the Apps Service never start properly. I have to try different work-around like unsetting and setting g the pool, reboot, disable SMB services multiple times before I can make it to work again.
Sometimes I get kubernetes error, everyime is different from the previous one.
I did search in the forums for the solution but none was helpful.
The only thing out of place is my pool status check: I notice that my boot pool is damage.
Here the result of 'zpool status':
I think (and I hope) that my problems are there because of the boot-pool degraded.
Should I reinstall the OS on my SSD pool? Is it safe and easy?
My HDD held tons movies and some photos. I can save my photos on my PC's SSD and format everything but I really don't wanna lose all my movies and anime that I downloaded.
If I install my OS again, I can import my old pool without losing my data? Is there a guide?
If you need me to do something else to check, to help you troubleshoot, just ask (like testing my HDD writing speed or something else).
Thank you.
Robi. :)
P.S.
My PC doesn't have issue downloading at 2,5 Gb/s speed from the internet. Dunno if you need this info or not.
And sorry for my English, my first language is Italian so please be kind to me.
Hardware:
Motherboard: B550I AORUS PRO AX
CPU: AMD Ryzen 5 5600G
RAM: 2 x 16 GB Crucial Pro DDR4 3200 MHz (CP2K16G4DFRA32A)
Boot SSD: Kingston A400 SSD 240GB 2.5" SATA (SA400S37/240G)
Cache SSD: Samsung 980 250 GB NVMe M.2 (MZ-V8V250BW)
HDD for DATA: 5 x 2 TB Seagate BarraCuda (SMR - ST20000DM008) - I know it's not the best but I found it out too late.
Power Supply: Cooler Master V750 SFX Gold
Software:
OS Version: TrueNAS-SCALE-23.10.1.3
Configuration:
Data VDEVs: 1 x RAIDZ1 (with 5 x 2TB HDD)
Cache VDEVs: 1 x 250 GB SSD NVMe M.2
Capacity used: 2,09 TiB (29,1%)
root@truenas[~]# zpool status
pool: Sanji-SAN
state: ONLINE
scan: scrub repaired 0B in 00:29:46 with 0 errors on Sun Jan 28 00:29:48 2024
NAME STATE READ WRITE CKSUM
Sanji-SAN ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
4529bb42-9a64-47bf-84ee-ca8f26b30520 ONLINE 0 0 0
15ee06d0-27b7-4a9b-87aa-ff406409becb ONLINE 0 0 0
1a7f08f1-a551-429a-b1df-ee50ab7910be ONLINE 0 0 0
ab8081da-6abc-4e6c-a3bd-e07a73398011 ONLINE 0 0 0
820e7a70-3168-4b49-a83e-8c390cf8e1e8 ONLINE 0 0 0
cache
bb28a548-06a6-42c7-90b7-a87ec6b7b14c ONLINE 0 0 0
errors: No known data errors
pool: boot-pool
state: DEGRADED
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
scan: scrub repaired 0B in 00:00:47 with 0 errors on Fri Feb 16 03:45:48 2024
boot-pool DEGRADED 0 0 0
sdd3 DEGRADED 14 0 42 too many errors
Thank you.
Robi. :)
P.S.
Hardware:
Software:
Configuration:
