Read SMART Self-Test Log Failed
Agi
Got an email recently, freenas alert has dropped to critical (from healthy).
CRITICAL: 		 	 	 	Feb. 5, 2018, 9:37 p.m. - Device: /dev/da4 [SAT], Read SMART Self-Test Log Failed
Drives are on a servercase backplane sc4324 (same as the norco one).
Backplane is connected to HP sas expander and that connected (dual link) to a flashed Dell H200 (LSI 9211).
I ran smartctl -a:
root@freenas:~ # smartctl -a /dev/da4
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Seagate IronWolf
Device Model:	 ST6000VN0041-2EL11C
Serial Number:	ZA15XX1V
LU WWN Device Id: 5 000c50 0937d836b
Firmware Version: SC61
User Capacity:	6,001,175,126,016 bytes [6.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	7200 rpm
Form Factor:	  3.5 inches
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 1.5 Gb/s)
Local Time is:	Mon Feb  5 21:57:31 2018 GMT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)   Offline data collection activity
				   was completed without error.
Self-test execution status:	  (   0)   The previous self-test routine completed
				   been run.
data collection:		(  575) seconds.
capabilities:			 (0x7b) SMART execute Offline immediate.
				   command.
				   Self-test supported.
SMART capabilities:			(0x0003)   Saves SMART data before entering
				   power-saving mode.
Error logging capability:		(0x01)   Error logging supported.
Short self-test routine
recommended polling time:	 (   1) minutes.
Extended self-test routine
recommended polling time:	 ( 605) minutes.
Conveyance self-test routine
recommended polling time:	 (   2) minutes.
SCT capabilities:		   (0x50bd)   SCT Status supported.
				   SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x000f   083   064   044	Pre-fail  Always	   -	   190240880
  3 Spin_Up_Time			0x0003   085   085   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   12
  5 Reallocated_Sector_Ct   0x0033   100   100   010	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000f   093   060   045	Pre-fail  Always	   -	   1808699159
  9 Power_On_Hours		  0x0032   093   093   000	Old_age   Always	   -	   6940 (107 132 0)
 10 Spin_Retry_Count		0x0013   100   100   097	Pre-fail  Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   12
184 End-to-End_Error		0x0032   100   100   099	Old_age   Always	   -	   0
187 Reported_Uncorrect	  0x0032   100   100   000	Old_age   Always	   -	   0
188 Command_Timeout		 0x0032   100   100   000	Old_age   Always	   -	   0
189 High_Fly_Writes		 0x003a   100   100   000	Old_age   Always	   -	   0
190 Airflow_Temperature_Cel 0x0022   070   057   040	Old_age   Always	   -	   30 (Min/Max 29/33)
191 G-Sense_Error_Rate	  0x0032   095   095   000	Old_age   Always	   -	   11319
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   8
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   201
194 Temperature_Celsius	 0x0022   030   043   000	Old_age   Always	   -	   30 (0 22 0 0 0)
195 Hardware_ECC_Recovered  0x001a   002   001   000	Old_age   Always	   -	   190240880
197 Current_Pending_Sector  0x0012   100   100   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0010   100   100   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   0
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   6937 (110 118 0)
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   63931105220
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   92353073452
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	  6920		 -
# 2  Short offline	   Completed without error	   00%	  6683		 -
# 3  Extended offline	Completed without error	   00%	  6636		 -
# 4  Short offline	   Completed without error	   00%	  6515		 -
# 5  Short offline	   Completed without error	   00%	  6347		 -
# 6  Short offline	   Completed without error	   00%	   802		 -
# 7  Extended offline	Completed without error	   00%	   716		 -
# 8  Short offline	   Completed without error	   00%	   634		 -
# 9  Short offline	   Completed without error	   00%	   466		 -
#10  Extended offline	Completed without error	   00%	   380		 -
#11  Short offline	   Completed without error	   00%	   298		 -
#12  Short offline	   Completed without error	   00%	   114		 -
#13  Extended offline	Interrupted (host reset)	  00%	   114		 -
#14  Short offline	   Aborted by host			   10%	   103		 -
#15  Extended offline	Completed without error	   00%		19		 -
#16  Conveyance offline  Completed without error	   00%		10		 -
#17  Short offline	   Completed without error	   00%		10		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Seems ok to me?
For completion, zpool status:
root@freenas:~ # zpool status
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0 days 00:00:08 with 0 errors on Fri Feb  2 03:45:08 2018
   NAME		STATE	 READ WRITE CKSUM
   freenas-boot  ONLINE	   0	 0	 0
	 ada0p2	ONLINE	   0	 0	 0
errors: No known data errors
  pool: pooly
 state: ONLINE
  scan: scrub repaired 0 in 0 days 08:15:05 with 0 errors on Thu Feb  1 11:15:07 2018
   pooly										   ONLINE	   0	 0	 0
	 raidz2-0									  ONLINE	   0	 0	 0
	   gptid/9120ced5-d71b-11e6-a3fe-0025905d5838  ONLINE	   0	 0	 0
	   gptid/1e6c031a-e0b4-11e6-bb66-0025905d5838  ONLINE	   0	 0	 0
	   gptid/90845583-e076-11e5-8f0e-0025905d5838  ONLINE	   0	 0	 0
	   gptid/926d54b6-e076-11e5-8f0e-0025905d5838  ONLINE	   0	 0	 0
	   gptid/94350a8b-e076-11e5-8f0e-0025905d5838  ONLINE	   0	 0	 0
	   gptid/960fa249-e076-11e5-8f0e-0025905d5838  ONLINE	   0	 0	 0
	 raidz2-1									  ONLINE	   0	 0	 0
	   gptid/1760d282-2b2b-11e7-bb44-0025905d5838  ONLINE	   0	 0	 0
	   gptid/181ae329-2b2b-11e7-bb44-0025905d5838  ONLINE	   0	 0	 0
	   gptid/18e63ada-2b2b-11e7-bb44-0025905d5838  ONLINE	   0	 0	 0
	   gptid/19b406da-2b2b-11e7-bb44-0025905d5838  ONLINE	   0	 0	 0
	   gptid/1a929c1d-2b2b-11e7-bb44-0025905d5838  ONLINE	   0	 0	 0
	   gptid/1b69ec47-2b2b-11e7-bb44-0025905d5838  ONLINE	   0	 0	 0
Should I be worried?
Nick2253
I would not be immediately concerned, but I would stay vigilant. This could be random, or it could point to a developing problem with the hdd, cable, backplane, or controller. If you see this error again, especially if it's the same drive, then I'd dig in more. In any case, now is a great time to make sure your replacement drive is on-hand and ready.
jamiejunk
This has been happening to ALL my FreeNAS-11.X boxes. All my older installs are fine. But once I upgrade them to 11, BAM, start getting this error.
