MichaelBatz
- Apr 30, 2015
Hey everybody!
I received this mail.
The first thing I did was to create a RMA for the HDD, because the warranty expires in less than a month. The RMA got accepted within 10 min.
I did some more testing. Now I am a little in doubt on how to proceed.
I did an extended offline test, and i scrubbed the pool.
The values for both Current_Pending_Sector and Offline_Uncorrectable are now 0, and the extended offline test have completed without any errors.
If I should RMA this HDD, then they would probably just return it to me, and charge for a lot of money. Not interested in that. How to proceed? I still have a great suspicions that this HDD is slowly dying. Or I'm just being too paranoid?
HTML:
Device: /dev/ada1, 8 Currently unreadable (pending) sectors
Device: /dev/ada1, 8 Offline uncorrectable sectors
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST3000DM001-1CH166
Serial Number: Z1F4BT5K
LU WWN Device Id: 5 000c50 065b0c5b8
Firmware Version: CC27
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Jun 15 10:16:36 2016 CEST
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 584) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 329) minutes.
Conveyance self-test routine
SCT capabilities: (0x3085) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 106 099 006 Pre-fail Always - 11595224
3 Spin_Up_Time 0x0003 093 093 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 096 096 020 Old_age Always - 4759
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 085 060 030 Pre-fail Always - 372164430
9 Power_On_Hours 0x0032 084 084 000 Old_age Always - 14516
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 41
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 1
189 High_Fly_Writes 0x003a 099 099 000 Old_age Always - 1
190 Airflow_Temperature_Cel 0x0022 062 037 045 Old_age Always In_the_past 38 (Min/Max 23/43 #2692)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 34
193 Load_Cycle_Count 0x0032 041 041 000 Old_age Always - 119380
194 Temperature_Celsius 0x0022 038 063 000 Old_age Always - 38 (0 20 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 12551h+37m+17.098s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 46003325539
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 197852327815
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 14440 -
# 2 Extended offline Completed without error 00% 14350 -
# 3 Short offline Completed without error 00% 14272 -
# 4 Short offline Completed without error 00% 14118 -
# 5 Extended offline Completed without error 00% 14105 -
# 6 Extended offline Completed: read failure 20% 14028 -
# 7 Short offline Completed without error 00% 13950 -
# 8 Short offline Completed without error 00% 13782 -
# 9 Extended offline Completed without error 00% 13693 -
#10 Short offline Completed without error 00% 13614 -
#11 Short offline Completed without error 00% 13398 -
#12 Extended offline Completed without error 00% 13309 -
#13 Short offline Completed without error 00% 13230 -
#14 Short offline Completed without error 00% 13062 -
#15 Extended offline Completed without error 00% 12972 -
#16 Short offline Completed without error 00% 12894 -
#17 Short offline Completed without error 00% 12656 -
#18 Extended offline Completed without error 00% 12565 -
#19 Short offline Completed without error 00% 12488 -
#20 Short offline Completed without error 00% 12319 -
#21 Extended offline Completed without error 00% 12230 -
1 of 1 failed self-tests are outdated by newer successful extended offline self-test # 2
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
pool: tank
state: ONLINE
scan: scrub repaired 0 in 45h56m with 0 errors on Thu Jun 2 22:56:56 2016
NAME STATE READ WRITE CKSUM
tank ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/7d0d4614-1d70-11e5-9640-0cc47a31d318 ONLINE 0 0 0
gptid/7d9d0f81-1d70-11e5-9640-0cc47a31d318 ONLINE 0 0 0
gptid/7e1863a0-1d70-11e5-9640-0cc47a31d318 ONLINE 0 0 0
gptid/7e8c4e54-1d70-11e5-9640-0cc47a31d318 ONLINE 0 0 0
gptid/7f03f0cd-1d70-11e5-9640-0cc47a31d318 ONLINE 0 0 0
gptid/7fa080f2-1d70-11e5-9640-0cc47a31d318 ONLINE 0 0 0
gptid/8018dd86-1d70-11e5-9640-0cc47a31d318 ONLINE 0 0 0
gptid/80ac89ef-1d70-11e5-9640-0cc47a31d318 ONLINE 0 0 0
gptid/811ff591-1d70-11e5-9640-0cc47a31d318 ONLINE 0 0 0
gptid/8180504c-1d70-11e5-9640-0cc47a31d318 ONLINE 0 0 0
errors: No known data errors
