Brosif_My_Nif
- Jan 12, 2012
I have been working on resolving this error for the past few weeks, but I've ran up against a wall. I have searched and tried some of the suggestions I thought may be applicable, but I am unable to resolve this error.
I am unable to change the permissions on one of my datasets ("PICTURES"). When I try to change the permissions via the GUI, I receive the following "Read-only file system" errors and it will not update the permissions for the dataset "PICTURES".
If I copy a folder outside of the Read-only "PICTURES" dataset, I can then recursively change permissions via the GUI and regain access to that particular folder inside a new temporary dataset.
A few quick details:
Shell Command "ls -lo" provides me with the following. I had to create a temporary dataset ("photography") because I am unable to write inside my normal "PICTURES" dataset where I currently have about 16TB of photos stored (both personal and business).
Please let me know if you have any suggestions I can try. I greatly appreciate any assistance you can offer.
If I am unable to resolve the problem, the next thing I was going to try is using the shell command "cp -R" to copy all my folders from the Read-only "PICTURES" dataset to the newly created "PHOTOGRAPHY" dataset where I have write privileges and then recursively changing the permissions via the GUI once everything is copied over. I hope I don't have to do that...
Thanks again in advance!
chown: /mnt/NAS_Volume2/PICTURES: Read-only file system
chmod: /mnt/NAS_Volume2/PICTURES: Read-only file system
- FreeNAS-9.10-STABLE-201604261518 (881b70d)
- CIFS settings are default
- Permissions Type set to "Unix" for all Datasets under Storage -> Volumes -> Change Permissions
- Mixed Windows & OSX Environment ... All permissions have been handled on the FreeNAS side and I have never experienced this kind of problem the past few years.
- This error started after I copied my datasets via "Replication Tasks" over to some new 8TB Reds I purchased to expand my pool.
- Fresh FreeNAS install
