Read error?
RichTJ99
I received an email last night from my freenas box. Should I be concerned about this? A read error doesnt sound good to me.
Thanks,
Rich
freenasvm.local kernel log messages:
>   (da5:mpr0:0:5:0): READ(10). CDB: 28 00 79 a7 7e d8 00 00 38 00 length 28672 SMID 666 terminated ioc 804b scsi 0 state 0 xfer 0
> (da5:mpr0:0:5:0): CAM status: CCB request completed with an error
> (da5:mpr0:0:5:0): Retrying command
> (da5:mpr0:0:5:0): READ(10). CDB: 28 00 79 a7 7e a8 00 00 30 00
> (da5:mpr0:0:5:0): CAM status: SCSI Status Error
> (da5:mpr0:0:5:0): SCSI status: Check Condition
> (da5:mpr0:0:5:0): SCSI sense: MEDIUM ERROR asc:11,0 (Unrecovered read error)
> (da5:mpr0:0:5:0): Info: 0x79a77ea8
> (da5:mpr0:0:5:0): Error 5, Unretryable error
-- End of security output --
melloa
I would.
There are several posts in the forum about smart tests and how to interpret them. Also back-up whatever is important before it gets worse ...
RichTJ99
This is my back freenas box. I will give smart tests a shot & see whats happening. I wasnt sure if it was a hardware error or something else.
RichTJ99
So I setup the smart test & no errors were reported or emailed? Was it a one time thing?
Robert Trevellyan
Pony Wrangler
Did you enable the SMART check service, or did you set up a SMART test task?
SMART checks look at a disk's built-in SMART attributes, which the drive updates continuously.
SMART tests run a disk's self-test routines, and either pass or fail.
In either case, you should receive an email alert of anything that is cause for concern, but it doesn't hurt to look at the status of each disk from time to time. To do that, you run smartctl -a <devname> or smartctl -x <devname> at the command-line.
The error reported in your original post might indicate a problem with da5, but it could also be a cable or port problem. For a 2nd opinion, post (between CODE tags) the output of smartctl -x /dev/da5.
RichTJ99
Here we are - thanks for checking into this.
smartctrl -x /dev/da5
login as: root
root@192.168.168.51's password:
Last login: Wed Dec 14 13:30:32 2016 from 192.168.168.37
FreeBSD 10.3-STABLE (FreeNAS.amd64) #0 r295946+07c41cd(9.10-STABLE): Wed Nov  9 00:19:25 UTC 2016
		FreeNAS (c) 2009-2016, The FreeNAS Development Team
		All rights reserved.
		FreeNAS is released under the modified BSD license.
		For more information, documentation, help or support, go here:
		http://freenas.org
Welcome to FreeNAS
[root@freenasvm] ~# smartctl -x /dev/da5
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Western Digital Red
Device Model:	 WDC WD60EFRX-68L0BN1
Serial Number:	WD-WXB1HB4JWHLC
LU WWN Device Id: 5 0014ee 2b7c627bf
Firmware Version: 82.00A82
User Capacity:	6,001,175,126,016 bytes [6.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5700 rpm
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Wed Dec 14 17:00:44 2016 EST
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
										was never started.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				( 4064) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 694) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x303d) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAGS	VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate	 POSR-K   200   200   051	-	0
  3 Spin_Up_Time			POS--K   214   214   021	-	8258
  4 Start_Stop_Count		-O--CK   100   100   000	-	8
  5 Reallocated_Sector_Ct   PO--CK   200   200   140	-	0
  7 Seek_Error_Rate		 -OSR-K   100   253   000	-	0
  9 Power_On_Hours		  -O--CK   098   098   000	-	2062
 10 Spin_Retry_Count		-O--CK   100   253   000	-	0
 11 Calibration_Retry_Count -O--CK   100   253   000	-	0
 12 Power_Cycle_Count	   -O--CK   100   100   000	-	8
192 Power-Off_Retract_Count -O--CK   200   200   000	-	3
193 Load_Cycle_Count		-O--CK   200   200   000	-	32
194 Temperature_Celsius	 -O---K   124   110   000	-	28
196 Reallocated_Event_Count -O--CK   200   200   000	-	0
197 Current_Pending_Sector  -O--CK   200   200   000	-	0
198 Offline_Uncorrectable   ----CK   100   253   000	-	0
199 UDMA_CRC_Error_Count	-O--CK   200   200   000	-	0
200 Multi_Zone_Error_Rate   ---R--   200   200   000	-	0
							||||||_ K auto-keep
							|||||__ C event count
							||||___ R error rate
							|||____ S speed/performance
							||_____ O updated online
							|______ P prefailure warning
General Purpose Log Directory Version 1
SMART		   Log Directory Version 1 [multi-sector log support]
Address	Access  R/W   Size  Description
0x00	   GPL,SL  R/O	  1  Log Directory
0x01		   SL  R/O	  1  Summary SMART error log
0x02		   SL  R/O	  5  Comprehensive SMART error log
0x03	   GPL	 R/O	  6  Ext. Comprehensive SMART error log
0x06		   SL  R/O	  1  SMART self-test log
0x07	   GPL	 R/O	  1  Extended self-test log
0x09		   SL  R/W	  1  Selective self-test log
0x10	   GPL	 R/O	  1  SATA NCQ Queued Error log
0x11	   GPL	 R/O	  1  SATA Phy Event Counters log
0x21	   GPL	 R/O	  1  Write stream error log
0x22	   GPL	 R/O	  1  Read stream error log
0x30	   GPL,SL  R/O	  9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W	 16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS	  16  Device vendor specific log
0xa8-0xb6  GPL,SL  VS	   1  Device vendor specific log
0xb7	   GPL,SL  VS	  54  Device vendor specific log
0xbd	   GPL,SL  VS	   1  Device vendor specific log
0xc0	   GPL,SL  VS	   1  Device vendor specific log
0xc1	   GPL	 VS	  93  Device vendor specific log
0xe0	   GPL,SL  R/W	  1  SCT Command/Status
0xe1	   GPL,SL  R/W	  1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 1
		CR	 = Command Register
		FEATR  = Features Register
		COUNT  = Count (was: Sector Count) Register
		LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
		LH	 = LBA High (was: Cylinder High) Register	]   LBA
		LM	 = LBA Mid (was: Cylinder Low) Register	  ] Register
		LL	 = LBA Low (was: Sector Number) Register	 ]
		DV	 = Device (was: Device/Head) Register
		DC	 = Device Control Register
		ER	 = Error register
		ST	 = Status register
Error 1 [0] occurred at disk power-on lifetime: 1981 hours (82 days + 13 hours)
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 51 00 00 00 00 79 a7 7e a8 40 00  Error: UNC at LBA = 0x79a77ea8 = 2041020072
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  60 00 38 00 08 00 00 79 a7 7e d8 40 00 39d+16:43:51.474  READ FPDMA QUEUED
  60 00 30 00 00 00 00 79 a7 7e a8 40 00 39d+16:43:51.473  READ FPDMA QUEUED
  60 00 38 00 08 00 00 79 a7 7e 70 40 00 39d+16:43:51.463  READ FPDMA QUEUED
  60 00 a0 00 00 00 00 79 a7 7d d0 40 00 39d+16:43:51.462  READ FPDMA QUEUED
  60 00 30 00 08 00 00 79 a7 7d a0 40 00 39d+16:43:51.448  READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	  2057		 -
# 2  Short offline	   Completed without error	   00%	  2051		 -
# 3  Short offline	   Completed without error	   00%	  2045		 -
# 4  Short offline	   Completed without error	   00%	  2039		 -
# 5  Short offline	   Completed without error	   00%	  2033		 -
# 6  Short offline	   Completed without error	   00%	  2027		 -
# 7  Short offline	   Completed without error	   00%	  2021		 -
# 8  Short offline	   Completed without error	   00%	  2015		 -
# 9  Extended offline	Completed without error	   00%	   158		 -
#10  Extended offline	Interrupted (host reset)	  30%	   146		 -
#11  Extended offline	Completed without error	   00%		12		 -
#12  Conveyance offline  Completed without error	   00%		 0		 -
#13  Short offline	   Completed without error	   00%		 0		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
SCT Status Version:				  3
SCT Version (vendor specific):	   258 (0x0102)
SCT Support Level:				   1
Device State:						Active (0)
Current Temperature:					28 Celsius
Power Cycle Min/Max Temperature:	 25/32 Celsius
Lifetime	Min/Max Temperature:	 21/42 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:	 2
Temperature Sampling Period:		 1 minute
Temperature Logging Interval:		1 minute
Min/Max recommended Temperature:	  0/60 Celsius
Min/Max Temperature Limit:		   -41/85 Celsius
Temperature History Size (Index):	478 (353)
Index	Estimated Time   Temperature Celsius
 354	2016-12-14 09:03	28  *********
 ...	..( 48 skipped).	..  *********
 403	2016-12-14 09:52	28  *********
 404	2016-12-14 09:53	29  **********
 ...	..(150 skipped).	..  **********
  77	2016-12-14 12:24	29  **********
  78	2016-12-14 12:25	28  *********
 ...	..(274 skipped).	..  *********
 353	2016-12-14 17:00	28  *********
SCT Error Recovery Control:
		   Read:	 70 (7.0 seconds)
		  Write:	 70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID	  Size	 Value  Description
0x0001  2			0  Command failed due to ICRC error
0x0002  2			0  R_ERR response for data FIS
0x0003  2			0  R_ERR response for device-to-host data FIS
0x0004  2			0  R_ERR response for host-to-device data FIS
0x0005  2			0  R_ERR response for non-data FIS
0x0006  2			0  R_ERR response for device-to-host non-data FIS
0x0007  2			0  R_ERR response for host-to-device non-data FIS
0x0008  2			0  Device-to-host non-data FIS retries
0x0009  2			1  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2		   11  Device-to-host register FISes sent due to a COMRESET
0x000b  2			0  CRC errors within host-to-device FIS
0x000d  2			0  Non-CRC errors within host-to-device FIS
0x000f  2			0  R_ERR response for host-to-device data FIS, CRC
0x0012  2			0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4	  3719857  Vendor specific
[root@freenasvm] ~#
[root@freenasvm] ~# smartctl -a /dev/da5
Local Time is:	Wed Dec 14 16:58:03 2016 EST
										was never started.
										been run.
										command.
										power-saving mode.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   214   214   021	Pre-fail  Always	   -	   8258
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   8
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   100   253   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   098   098   000	Old_age   Always	   -	   2062
 10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   8
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   3
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   32
194 Temperature_Celsius	 0x0022   124   110   000	Old_age   Always	   -	   28
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   0
SMART Error Log Version: 1
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
joeschmuck
Old Man
Here is what I see:
1. You just recently setup running SMART Short Tests every 6 hours. Recommend changing this to once a day.
2. You do not have SMART Long Tests currently setup possibly, ensure you set this up to once a week. Both of these are my personal preferences, you can select something else if you like.
3. You have a single failure at hour 1981 (3 days ago). Since I see no corresponding failure I'd just keep an eye on this, specifically LBA
2041020072. Because of this failure you may want to change the SMART Long Test to once a night for a few weeks. This will test the drive while you sleep and if something fails, you should get an email stating such. Then go through the Hard Drive Troubleshooting Guide and see what the issue it. Odds are, if you get another failure you would be at the point to RMA the drive but I see nothing to substantiate it right now.
Robert Trevellyan
Pony Wrangler
Based on the logs, my guess is a SMART extended test will report a read failure at LBA 2041020072. If so, it's grounds for an RMA. You could just keep an eye on it and see what happens, or you could burn it in again with badblocks and return it if the problem persists.
RichTJ99
Thanks! I made the changes and will report back in a few weeks unless I get an error sooner!
tobiasbp
[/CODE]
Did you resolve the issue? I think we might the same problem. After having replaced almost everything in my machine, it turns out, the drive with worst behaviour is of type WD60EFRX-68L0BN1 just like yours. Other disks with device type WD60EFRX-68MYMN1 in my zpool, do not exibit the same behaviour (Throwing SCSI errors).
