Re-IP TrueNAS.
da_da
How can I Re-IP the TrueNAS using one command. for example, my truenas IP is 10.1.1.22/24 DG 10.1.1.1. how do I change the IP to 10.2.2.22/24 DG 10.2.2.1 in one command. Currently, running the latest. I see that the rc.conf does not have the IP addressing.
Use the webGUI.
da_da
The DG location is on another tab and once you select and save, then you would loose connectivity.
When you make network changes, you apply the changes and it will give you 60 seconds to accept the change or it will revert back to the previous settings.
Use the webGUI. Changes made via the command line will not save or persist on re-boot. You have been so advised.
da_da
I went ahead and used netcli anyways, now qbitorrent won't load as well as Plex. I have changed their IP's properly. :(
Patrick M. Hausen
Did you change the gateway and possibly the nameserver accorsing to your IP address change? It's in Network > Global Settings.
da_da
yes I did.
It looks like Qbitorrent will not start at all. when I started it manually, none of my torrents whoed up. :( oh man!
