Glorious1
 - Nov 23, 2014
I started a scrub of one of my volumes and noticed in the console right away, one the drives had a bunch of read errors.  The smartctl output (below) shows 78 raw read errors.  Last time I looked it was 0.  Down below it reports 5 ATA errors.
Does this mean the drive is hosed? Of the four WD Red NASs I bought, I've already returned one. This would be a 50% failure rate in less than 2 months!
 $ sudo smartctl -a /dev/ada1
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p8 amd64] (local build)
Model Family:     Western Digital Red (AF)
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-WMC4N0F613XU
LU WWN Device Id: 5 0014ee 65a73cfc9
Firmware Version: 82.00A82
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Jan 29 09:32:13 2015 MST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (38940) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 391) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       78
  3 Spin_Up_Time            0x0027   178   173   021    Pre-fail  Always       -       6100
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       229
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   100   253   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       1181
10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       66
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       35
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       733
194 Temperature_Celsius     0x0022   115   114   000    Old_age   Always       -       35
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
ATA Error Count: 5
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 5 occurred at disk power-on lifetime: 1180 hours (49 days + 4 hours)
  ER ST SC SN CL CH DH
  40 51 00 b8 74 3e 45  Error: UNC at LBA = 0x053e74b8 = 87979192
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  c8 00 00 28 74 3e 45 08   7d+20:35:57.593  READ DMA
  ec 00 01 00 00 00 40 08   7d+20:35:57.593  IDENTIFY DEVICE
  c8 00 00 28 74 3e 45 08   7d+20:35:50.591  READ DMA
  e5 00 00 00 00 00 40 08   7d+20:35:50.591  CHECK POWER MODE
  c8 00 00 28 74 3e 45 08   7d+20:35:43.592  READ DMA
Error 4 occurred at disk power-on lifetime: 1180 hours (49 days + 4 hours)
  40 51 00 78 74 3e 45  Error: UNC at LBA = 0x053e7478 = 87979128
  c8 00 00 28 74 3e 45 08   7d+20:35:36.591  READ DMA
  c8 00 00 28 74 3e 45 08   7d+20:35:29.592  READ DMA
Error 3 occurred at disk power-on lifetime: 1180 hours (49 days + 4 hours)
  40 51 00 7f 74 3e 45  Error: UNC at LBA = 0x053e747f = 87979135
Error 2 occurred at disk power-on lifetime: 1180 hours (49 days + 4 hours)
  40 51 00 df 74 3e 45  Error: UNC at LBA = 0x053e74df = 87979231
Error 1 occurred at disk power-on lifetime: 1180 hours (49 days + 4 hours)
  40 51 00 c8 74 3e 45  Error: UNC at LBA = 0x053e74c8 = 87979208
# 1  Short offline       Completed without error       00%      1087         -
# 2  Short offline       Completed without error       00%       967         -
# 3  Short offline       Completed without error       00%       663         -
# 4  Extended offline    Completed without error       00%       525         -
# 5  Short offline       Completed without error       00%       254         -
# 6  Short offline       Completed without error       00%       206         -
# 7  Short offline       Completed without error       00%       180         -
# 8  Short offline       Completed without error       00%       156         -
# 9  Short offline       Completed without error       00%       132         -
#10  Extended offline    Completed without error       00%        82         -
#11  Extended offline    Completed without error       00%        24         -
#12  Short offline       Completed without error       00%        17         -
#13  Conveyance offline  Completed without error       00%        17         -
