SpaceAvenger69
- Feb 4, 2015
I am running the latest stable version of FreeNAS (9.3) and am running Sonarr (v. 2.0.0.3357) via the plugin. Sonarr is working great with the exception of using RarBG for an indexer. I am able to set this up when running Windows 7 in a VM but would like to get it set up in the plugin version.
The log file shows:
15-8-26 11:53:34.8|Warn|Rarbg|Unable to connect to indexer: Error: SendFailure (Error writing headers)
System.Net.WebException: Error: SendFailure (Error writing headers) ---> System.Net.WebException: Error writing headers ---> System.IO.IOException: The authentication or decryption has failed. ---> Mono.Security.Protocol.Tls.TlsException: The authentication or decryption has failed.
at Mono.Security.Protocol.Tls.RecordProtocol.ProcessAlert (AlertLevel alertLevel, AlertDescription alertDesc) [0x00000] in <filename unknown>:0
at Mono.Security.Protocol.Tls.RecordProtocol.InternalReceiveRecordCallback (IAsyncResult asyncResult) [0x00000] in <filename unknown>:0
--- End of inner exception stack trace ---
at Mono.Security.Protocol.Tls.SslClientStream.EndNegotiateHandshake (IAsyncResult result) [0x00000] in <filename unknown>:0
at Mono.Security.Protocol.Tls.SslStreamBase.AsyncHandshakeCallback (IAsyncResult asyncResult) [0x00000] in <filename unknown>:0
at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) [0x00000] in <filename unknown>:0
at System.Net.HttpWebRequest.GetResponse () [0x00000] in <filename unknown>:0
at NzbDrone.Common.Http.HttpClient.ExecuteWebRequest (NzbDrone.Common.Http.HttpRequest request, System.Net.HttpWebRequest webRequest) [0x00000] in <filename unknown>:0
15-8-26 11:53:34.8|Warn|NzbDroneErrorPipeline|Invalid request Validation failed:
-- Unable to connect to indexer, check the log for more details
Any help in getting this set up correctly would be greatly appreciated.
TIA
The log file shows:
TIA
