"as soon as they hit the RAM ZIL" ... that doesn't begin to make any sense.
https://forums.freenas.org/index.php?threads/some-insights-into-slog-zil-with-zfs-on-freenas.13633/
Write performance with a SLOG is always a lot less than it is without. Here's some idea of what's happening under the hood when you request a sync write:
A sync write starts at the client, and has to make a very complicated round trip, in lockstep, for EACH WRITE REQUEST. The "sync" part of "sync write" means that the client is requesting that the current data block be confirmed as written to disk before the write() system call returns to the client. Without sync writes, a client is free to just stack up a bunch of write requests and then they can send over a slowish channel, and they arrive when they can. Look at the layers:
Client initiates a write syscall
Client filesystem processes request
Filesystem hands this off to the network stack as NFS or iSCSI
Network stack hands this packet off to network silicon
Silicon transmits to switch
Switch transmits to NAS network silicon
NAS network silicon throws an interrupt
NAS network stack processes packet
Kernel identifies this as a NFS or iSCSI request and passes to appropriate kernel thread
Kernel thread passes request off to ZFS
ZFS sees "sync request", sees an available SLOG device
ZFS pushes the request to the SAS device driver
Device driver pushes to LSI SAS silicon
LSI SAS chipset serializes the request and passes it over the SAS topology
SAS or SATA SSD deserializes the request
SSD controller processes the request and queues for commit to flash
SSD controller confirms request
SSD serializes the response and pssses it back over the SAS topology
LSI SAS chipset receives the response and throws an interrupt
SAS device driver gets the acknowledgment and passes it up to ZFS
ZFS passes acknowledgement back to kernel NFS/iSCSI thread
NFS/iSCSI thread generates an acknowledgement packet and passes it to the network silicon
NAS network silicon transmits to switch
Switch transmits to client network silicon
Client network silicon throws an interrupt
Client network stack receives acknowledgement packet and hands it off to filesystem
Filesystem says "yay, finally, what took you so long" and releases the syscall, allowing the client program to move on.
That's what happens for EACH sync write request.
The trick to increasing write performance is to optimize as many of these steps as possible. One of the better optimizations possible is to get rid of SAS from the equation and go straight to NVMe, which eliminates some handling in the middle. For your particular case, with that 2603 CPU, another optimization is to get a better CPU that allows the NAS to process things faster. It isn't clear to me HOW much faster that would make it, just that it's a thing that affects performance.
