RaidZ2 Pool Offline after single disk failure and stupid mistake
cayuga
Version: TrueNAS-12.0-U1.1
32GB RAM
2x XEON E5450
RACKABLE System with Areca SATA controller (data disks all in pass-thru mode)
I had six data disks in "Pool1". One of them failed. I accidentally pulled the wrong disk to replace, realized my mistake and put it back, but now Pool1 is Offline:
System and five data disks are still visible to the system:
zpool status -v doesn't show Pool1
# zpool status -v
started 2021 Tue Mar 09 09:49:07 PM EST
  pool: freenas-boot
 state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
        still be used, but some features are unavailable.
        the features. See zpool-features(5) for details.
  scan: scrub repaired 0B in 00:00:19 with 0 errors on Mon Mar  8 03:45:19 2021
        NAME          STATE     READ WRITE CKSUM
        freenas-boot  ONLINE       0     0     0
          da0p2       ONLINE       0     0     0
errors: No known data errors
Am I out of luck? (I do have a backup, but would prefer to recover if possible).
What can/should I try next?
Thanks!
Jeff
Start with a look at zpool import
If your pool is listed there, we should have some idea of what the next options are
cayuga
Thanks!
I ran zpool status -x which showed me the missing pool :smile:
I then ran zpool import Pool1 which "failed" so I ran zpool import -F Pool1 and my pool was back (I lost 14 seconds of transactions which was fine).
It's been a few hours and everything seems to be working except my SMB share which I need to investigate.
(for anyone with a similar problem, I also had to export and import the pool in order for it to show up in the GUI)
