bitsquirrel
- Dec 30, 2017
Hello so I have an encrypted raidz2 pool with a faulted drive (da0).
I wanted to upgrade the entire array, but ran into snags.
What I did was, detach the entire array, reboot, and attempt to get the new drives to work.
The new 12TB SAS drives appear to not spin up; I think that is a "pin3 PWDIS" problem here:
https://www.tomshardware.com/news/hdd-sata-power-disable-feature,36146.html
Anyway, that's only one of my concerns. The second is how I got the array back up.
I'm running FreeNAS 11.1-U4.
On bootup the volume wasn't there - no surprise since I hadn't detached it.
When I tried to import the pool with 7/8 drives, I got an error that a particular volume was missing in the GUI.
I tried dropping down into shell, and did:
The weird thing was, it didn't seem to prompt for a passphrase at this point.
Then I did a:
Which I found here: https://github.com/zfsonlinux/zfs/issues/5567
And that seems to work:
So this looks good. But it's not showing up in the GUI.
Now to replace the faulted drive? First I check the partitioning.
That's the default, I guess, since I didn't set up swap partitions specifically.
I copied the partitioning from da1 to da0 as so:
Which I found here:
https://forums.freebsd.org/threads/copying-partitioning-to-new-disk.60937/
And then, I'm about to initialize geli on... I guess it'd be /dev/da0p2?
But then I realize I don't really know what I'm doing, and I decided to stop before going any further.
Can anyone tell me how to know exactly what FreeNAS did by default when I set up the encrypted raidz2 and how to replace this faulted drive?
In case it helps:
geli attach -K /path/to/geli.key -p /dev/da1 # for da1..da7
Then I did a:
zpool import -d /dev/; zpool import -f bu
# zpool status pool: bu state: DEGRADED status: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Attach the missing device and online it using 'zpool online'. see: http://illumos.org/msg/ZFS-8000-2Q scan: scrub repaired 0 in 0 days 10:02:29 with 0 errors on Sun Aug 5 10:02:55 2018 config: NAME STATE READ WRITE CKSUM bu DEGRADED 0 0 0 raidz2-0 DEGRADED 0 0 0 13617012186723571818 UNAVAIL 0 0 0 was /dev/gptid/d00af52c-f3f4-11e7-a858-001fbc11f330.eli da1p2.eli ONLINE 0 0 0 da2p2.eli ONLINE 0 0 0 da3p2.eli ONLINE 0 0 0 raidz2-1 ONLINE 0 0 0 da4p2.eli ONLINE 0 0 0 da5p2.eli ONLINE 0 0 0 da6p2.eli ONLINE 0 0 0 da7p2.eli ONLINE 0 0 0
# gpart show /dev/da1 => 40 7814037088 da1 GPT (3.6T) 40 88 - free - (44K) 128 4194304 1 freebsd-swap (2.0G) 4194432 7809842688 2 freebsd-zfs (3.6T) 7814037120 8 - free - (4.0K)
gpart backup da1 | gpart restore -F da0
Which I found here:
geli init -K /root/save/geli.key /dev/da0p2
In case it helps:
# geli list da1p2.eli Geom name: da1p2.eli State: ACTIVE EncryptionAlgorithm: AES-XTS KeyLength: 256 Crypto: hardware Version: 7 UsedKey: 0 Flags: NONE KeysAllocated: 932 KeysTotal: 932 Providers: 1. Name: da1p2.eli Mediasize: 3998639452160 (3.6T) Sectorsize: 4096 Mode: r1w1e1 Consumers: 1. Name: da1p2 Mediasize: 3998639456256 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1
