Hey Guys,
Since upgrading from 8.03 to 8.3 I've had this reoccuring problem. The amber light starts blinking in Freenas, I click it and it shows:
The volume Storage (ZFS) status is UNKNOWN: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'.
I then check "Volume" and see that my RaidZ1 is "healthy".. Hmm alright, drop down to the shell and type zpool status
With this I see "no known data errors" but I do see Checksums of 0/2/1/1
What does this mean? also I had this array running for 1.5 years with no errors, upgrade to 8.3 now everyday this happens.. It can't be the hardware. My array is 4x2TB WD Greens
Thx
Edit - Are UM errors Checksum Errors? if so, I assume this is just corrupted data not physically damaged drives? would make sense because once it shut down for no reason and mightve corrupted a few files
Thx
