Gruselgurke
- Sep 4, 2012
I currently get this error on my FreeNAS:
WARNING: The volume Data (ZFS) status is UNKNOWN: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'.
The console says /dev/ada1 has "1 Offline uncorrectable" and "1 Currently unreadable". I thought bad sectors would be resolved by the HDD or either the OS. How can I resolve this manually?
