- WARNING: The volume vol1 (ZFS) status is UNKNOWN: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'.
pool: vol1
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
see: http://www.sun.com/msg/ZFS-8000-9P
scan: scrub repaired 0 in 1h50m with 0 errors on Mon Jun 24 16:30:34 2013
NAME STATE READ WRITE CKSUM
vol1 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/1fcd253c-a3c8-11e2-8c16-a0f3c1000f31 ONLINE 0 0 0
gptid/208fc367-a3c8-11e2-8c16-a0f3c1000f31 ONLINE 0 0 166K
gptid/2130f319-a3c8-11e2-8c16-a0f3c1000f31 ONLINE 0 0 0
errors: No known data errors
Hello, I can't find out why I get the unknown status error. What is the problem? Can you please help? smart short test doesn't show any errors.
