If I understand what I have read then setting up a raidz with 1x2tb and 2x1tb drives will produce a 2tb raidz (two usable drives and one as a parity drive with the smallest drive in the set being the size used for all drives. Yes that is not an exact description just trying to keep it simple.)
Now, if in the future I decided I want to change that and slowly replace each drive with a 3tb drive allowing ample time for the rebuild, once all drives are at 3tb will the array become a 6tb array showing all available space?
Can you remove a drive hot and swap it with a new 3tb drive and let it auto-rebuild?
Thanks for the help
Thanks for the help
