Raid 6 hardware
dragon_sa
Hi, I have an LSI SAS2008 9211-8i with the IT version 20 firmware, I am wanting to run a raid 6 setup with 6 x WD Red Pro 8TB drives, is this card suitable for this and is it possible thru trunas, if not what card will I need to replace it with to achieve this?
Will be installed in a full tower running x64 system with an i7-3820 and 16gb ram
ChrisRJ
Do you mean RAID 6 or RAIDZ2 ?
Arwen
Yes, that should be a suitable card & firmware
I'd suggest reading the below doc, (it's not long at all). ZFS does not use RAID-6, but something that works similar called RAID-Z2;
dragon_sa
Thankyou Arwen for clarifying that for me, raidz2 looks like the way to go
